May 04, 2026, 02:08:45 AM *
Pages: 1 [2] 3
Author Topic: scanner's bobber  (Read 18776 times)
« Reply #15 on: October 28, 2014, 08:37:45 PM »
Can't imagine there would be a problem but I would definitely put some sort of guard on the front pulley. Getting your trouser leg caught could be nasty.
« Reply #16 on: October 28, 2014, 10:49:04 PM »
there is a cover for the front pully but the rear looks much better with out ,i might not remove thr mounting tabs til i see if it passes ok then they could get the chop
« Reply #17 on: November 14, 2014, 05:24:16 PM »
almost ready for paint,although i do need to make a side mount for the number plate
http://i1056.photobucket.com/albums/t373/Eddie096/C70581CF-AFBD-493D-8742-C283ACC961B4_zps7bezayyr.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/75FCAF9E-0C7C-4779-9187-104D7AA25BFF_zpssuqtwfgt.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/D2197990-D0C8-4656-9150-288CFECDFB02_zps2rlaj8mx.jpg
scanner's bobber
just hope there isn't too much suspension travel
« Reply #18 on: December 12, 2014, 03:58:03 PM »
well as it turns out even though the support is made from box section there is enough flex for it to rub the tyre so i have to put steady bars on after all,so with that in mind i,I've made a start on the number plate side mount. why i hear you ask ,well so as to be able to make the steady for the mudguard symmetrical i am going to mount the numberplate on the lift side of the swing arm and then the steady can go to it as well ,all will become clear as i progress so some pics to be going on with
got some u section to hold the numberplate and cut 2 V's in it to allow me to make 2 90 deg bends
http://i1056.photobucket.com/albums/t373/Eddie096/CAEF2CA9-2354-4710-A5EB-E89B38E70CF8_zpsxfe3rktw.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/C26BDECC-AF63-4908-AE50-FE65285A4860_zps63g9gupu.jpg
scanner's bobber
 and welded up the corners
http://i1056.photobucket.com/albums/t373/Eddie096/1F9DCB53-E1B6-4058-9801-2C7B86E9A19C_zpsuy3cjyqs.jpg
scanner's bobber
fits snuggly round the plate
http://i1056.photobucket.com/albums/t373/Eddie096/9598A137-308C-451E-9CBC-5DD4C7290550_zps6k0lbkr7.jpg
scanner's bobber
then welded 2 angles together to make a top
http://i1056.photobucket.com/albums/t373/Eddie096/FD98F0A1-28BD-44E7-9A9D-776840E81796_zpskhi6mwer.jpg
scanner's bobber
which also lets me mount a light above the plate
http://i1056.photobucket.com/albums/t373/Eddie096/4421F599-AEED-4C9F-B9D3-BCCC004AC8A9_zpsal7rxfi9.jpg
scanner's bobber
then it got toooo cold in the shed so you will have to wait for the next thrilling installment ! Shocked Shocked
« Reply #19 on: December 12, 2014, 07:01:05 PM »
Yup, definitely a chill in the air now. I've tried side mount plates on hardtail chops in the past & was always amazed how much bracing they needed. It's suprising how much they flex with vibration & wind pressure against them, especially on full sized, 9" x 7" plates.
« Reply #20 on: December 12, 2014, 07:12:08 PM »
hopefully the u channel will give it a bit of strength,I've still to make the mounts and as it's doubling as a mount for the mudguard they will have to up to the job !
« Reply #21 on: May 13, 2015, 07:50:48 PM »
well it's done just a bit of tidying and an mot now and we're set for summer , not happy with the paint match but it will do for this year now .Lesley thinks i've ruined it so .....have i  Huh
http://i1056.photobucket.com/albums/t373/Eddie096/65D8C15F-D916-4D67-B309-46A393D9E41A_zpszq9lpfn0.jpg
scanner's bobber
http://i1056.photobucket.com/albums/t373/Eddie096/34799961-D68B-4DD7-9349-DE809468282D_zpsmgup7ghm.jpg
scanner's bobber
i'll post some better pics when i get it off the lift
« Reply #22 on: May 13, 2015, 07:54:40 PM »
Nope, you haven't buddy!
Just get out and ride it!!! Cheesy Cheesy
« Reply #23 on: May 13, 2015, 08:08:05 PM »
I agree with Lesley ...Clive.
Just joking! Looks great matey. Now as Clive advised, get out & enjoy it!  Grin
« Reply #24 on: May 13, 2015, 09:42:42 PM »
thanks boys thats just what i plan to do Grin
« Reply #25 on: May 21, 2015, 09:19:03 PM »
all panels now back on and mot booked for next saturday
http://i1056.photobucket.com/albums/t373/Eddie096/53DCB064-F04B-449F-BF19-08C2FF5CF461_zpspjfztzhm.jpg
scanner's bobber
the plate looks tooooooo big ,would you take your chances with a smaller and illegal plate?
http://i1056.photobucket.com/albums/t373/Eddie096/F7BC00D0-15AF-4779-A64B-EA3AD312A66C_zpsbn3rbyhv.jpg
scanner's bobber
« Last Edit: May 21, 2015, 09:33:00 PM by scannerzer » Logged
Dslam
« Reply #26 on: May 22, 2015, 10:25:43 AM »
Nice conversion!
The plate does look humungus though.
Correct me if I am wrong but I am sure the number plate needs to be lit when the lights are on. Not sure if that's an MOT fail but may be worth checking out.
dr big750
« Reply #27 on: May 22, 2015, 10:56:24 AM »
Check out the last 2 pics and writing on reply 18 to clarify about the illumination
« Reply #28 on: May 22, 2015, 11:35:07 AM »
 thanks i like it ,always fancied a bobber.it has an led above it so all good
« Reply #29 on: May 30, 2015, 05:31:55 PM »
Now mot'd n ready for the road  Smiley tax it on Monday and hope for some dry weather!
Pages: 1 [2] 3
