March 17, 2026, 04:39:54 AM *
Pages: [1] 2 3 4
Author Topic: Brake pipe inside handlebars ?  (Read 19222 times)
andyrennison
« on: October 02, 2013, 11:03:14 PM »
As it says, has anyone done this?
Would like to run the pipe from the m/c down to the headstock inside the bars. Anyone Ideas?
Cheers
Andy
stumpy
« Reply #1 on: October 02, 2013, 11:59:01 PM »
i will be doing this with clutch and brake big ass bars all the better
steve brock
« Reply #2 on: October 03, 2013, 06:33:20 AM »
My BMW k100 motorbike i had, had brake pipes through the headstock using a tubular set up
http://i1061.photobucket.com/albums/t466/steveatthemorgue/reliant%20trike/null_zps8b3f8333.png
http://i1061.photobucket.com/albums/t466/steveatthemorgue/reliant%20trike/null_zpsea6b4f4b.png
andyrennison
« Reply #3 on: October 03, 2013, 09:53:48 AM »
Cheers guys.
I've put 1" bars on (3mm wall) so have some room for manoeuvre inside, not a lot but should be enough. Interesting your BMW had a solid tube in the headstock Steve. I had wondered about whether to use flexi or solid through the bars. Flexi will be easier to terminate nicely, fixed is much smaller but will require some clever thinking to terminate nicely outside the bars.
How you planning to do it Stumpy?
steve brock
« Reply #4 on: October 03, 2013, 11:17:51 AM »
Cheers guys.
It was hollow, you see the tube that the branded lines connected to it fed through the tube
stumpy
« Reply #5 on: October 03, 2013, 03:50:16 PM »
3/16 copper internal and make up braided lines to run on once im past headstock female joint on copper male joint on flexi banjos at masters easy
andyrennison
« Reply #6 on: October 03, 2013, 03:57:58 PM »
So the copper all the way to the master ?
stumpy
« Reply #7 on: October 03, 2013, 04:14:03 PM »
yup thread it through small hole in bars and flair it after .... i will post pics when i get there
andyrennison
« Reply #8 on: October 03, 2013, 04:41:06 PM »
grommet in the hole?
stumpy
« Reply #9 on: October 03, 2013, 05:00:56 PM »
noooo drill bit lol ... grommet a good precaution but will mean bigger hole  its your choice my hole will be on underside of bars so water less lightly to get in
andyrennison
« Reply #10 on: October 03, 2013, 05:48:55 PM »
Ha ha ha. Was wondering about Mr MSVA man more than water, sure any wires need grommets when going through holes. Good idea to put it on the bottom though - why didn't I think that - DOH!
ByzMax
Choppit
« Reply #11 on: October 04, 2013, 11:04:10 AM »
Would use a s/steel braided flexi hose myself.
http://www.choppit.co.uk
andyrennison
« Reply #12 on: October 04, 2013, 11:09:05 AM »
What's the thinking behind that vs copper ByzMax?
digger06
« Reply #13 on: October 04, 2013, 11:40:08 AM »
the braided may wear less if theres vibration?
iv seen copper ones wear through if chafing
andyrennison
« Reply #14 on: October 04, 2013, 12:16:44 PM »
Yeah, I was wondering about that myself, Stumpy seems happy enough with just copper though. Maybe copper with a rubber sleeve over my be the optimum. I was going to use braid originally, then looked at the size of the hole I would need in the bars and wondered about that. I may play this weekend with some mock ups.
Pages: [1] 2 3 4
