April 23, 2026, 09:53:42 PM *
Author Topic: Oil pressure sender location  (Read 4717 times)
« on: July 04, 2013, 09:53:50 PM »
Has anyone tried moving the location of the reliant oil pressure sender?
I am thinking about running a copper pipe from the original oil pressure take off point to under my fuel tank, so I can fit a hidden electronic sender.
Will it still read accurately ?
« Reply #1 on: July 04, 2013, 10:28:49 PM »
Yep, or at least it should do.
You can fit an adaptor between the block and the oil warning light switch with a port for the pipe to the electronic pressure sender, but this moves the switch out and makes it more vulnerable to being knocked.  I think you can you can leave the warning light switch as is and fit the pipe to one of the tapings on the oil gallery on the LH side of the engine.
« Reply #2 on: July 04, 2013, 10:34:56 PM »
Thanks ON, I couldn't think of a reason it wouldn't - but, you know.......
I am planning on running a nice polished pipe from the port on the block to below the tank, then fitting the T adapter up ther, so both the sender and the switch plus all the wiring will be hidden.
« Reply #3 on: July 05, 2013, 06:07:22 AM »
I was going to do this when I first built mine,but it got left as" one of those jobs I'll do later!" Admittedly I didnt look for very long,but I couldnt find a union that looked 'right'.as you say,it would clean up the whole area of wiring etc.
