March 13, 2026, 05:08:38 PM
Trike Tech
Reliant Halfshaft info req
Topic: Reliant Halfshaft info req (Read 3262 times)
July 02, 2013, 08:10:02 PM »
can some one tell me if there is any difference between the halfshaft for 57mm and 62mm bearings.
so can i swap the 62mm bearing for 57mm.
stumpy
Re: Reliant Halfshaft info req
July 03, 2013, 08:14:12 AM »
i just put new bearings right through my axle and when i ordered them it seems both external diameters share same id shaft ?
July 03, 2013, 09:57:49 AM »
Quote from: stumpy on July 03, 2013, 08:14:12 AM
Thanks stumpy My mates got a bent 57mm bearing shaft on he's trike. I have a shaft with 62mm bearings
stumpy
July 03, 2013, 04:37:24 PM »
job done ... be aware shafts can be plus or minus 10mm or so from axle to axle you may need a little trim
