March 13, 2026, 05:12:54 PM *
Author Topic: Reliant Halfshaft info req  (Read 3265 times)
« on: July 02, 2013, 08:10:02 PM »
can some one tell me if there is any difference between the halfshaft for 57mm and 62mm bearings.
so can i swap the 62mm bearing for 57mm. Huh
stumpy
« Reply #1 on: July 03, 2013, 08:14:12 AM »
i just put new bearings right through my axle and when i ordered them it seems both external diameters share same id shaft ?
« Reply #2 on: July 03, 2013, 09:57:49 AM »
Thanks stumpy My mates got a bent 57mm bearing shaft on he's trike.  I have a shaft with 62mm bearings
stumpy
« Reply #3 on: July 03, 2013, 04:37:24 PM »
job done ... be aware shafts can be plus or minus 10mm or so from axle to axle you may need a little trim
