April 17, 2026, 03:29:05 AM *
Pages: 1 [2]
Author Topic: Forks  (Read 5322 times)
« Reply #15 on: May 21, 2013, 05:38:00 PM »
Use a vernier gauge to measure the diameter of the fork tubes & the top of the fork bottoms. They should be able to tell you which one you need then.
« Reply #16 on: May 21, 2013, 06:15:29 PM »
If you are retaining the CX forks, then a good old steel brace, such as Mr. M suggested would be best, and the GL forks, which are the same as the CX's,  do in fact use a steel brace/mudguard support, under the front mudguard as standard, so a similar item made from 6mm M/S should improve things, and you have a pattern to follow, simples!!! Tongue Tongue Tongue Tongue Tongue
Pages: 1 [2]
