April 17, 2026, 03:29:41 AM *
Author Topic: Forks  (Read 5323 times)
skates
« on: May 20, 2013, 05:14:19 PM »
Ok so I've got piddly little cx500 forks on my trike. When I go round corners I think they are twisting a bit. So I thought I'd Change them to something bigger and beefier. The thing is I've been told I will need to cut the headstock off a weld a new one on. Is this right?
« Reply #1 on: May 20, 2013, 05:34:27 PM »
Not necessarily.
It's a matter of finding the right bearing setup to suit the headstock and the trees.
Try this
http://www.scribd.com/doc/3565510/motorcycle-steering-stem-bearing-sizes
« Last Edit: May 20, 2013, 05:45:57 PM by Old Newbie » Logged
« Reply #2 on: May 20, 2013, 05:47:00 PM »
Or a fork brace?
thebigdogsix
« Reply #3 on: May 20, 2013, 06:47:31 PM »
Or press your stem out and get the new yokes machined up to fit
« Reply #4 on: May 20, 2013, 07:05:38 PM »
No dramatic mods are required, as I have had similar probs. in the past with the GL/CX fork set up, so I swap them for Honda F1 750cc "4" forks. All that's required is a bottom taper roller change, see the attached pics. to illustrate, ...Morrag
« Reply #5 on: May 20, 2013, 07:14:30 PM »
Oh, and as suggested by Mr. M I use a fork brace, and the one in the pic. is made from 15mm thick, semi. hard grade aluminium alloy..........Morrag
skates
« Reply #6 on: May 20, 2013, 07:38:11 PM »
Did u have to lose the mudguard ?
« Reply #7 on: May 20, 2013, 07:57:04 PM »
No, not really, and for the MOT I would fit a new guard of flatter section, made from a section of discarded rear trailer mudguard, and that satisfied the MOT tester, ok.... Wink Wink Wink Morrag
skates
« Reply #8 on: May 21, 2013, 05:46:51 AM »
I would rather fit a brace but as I have a 19 inch front wheel I may have to lose the mudguard
« Reply #9 on: May 21, 2013, 10:09:12 AM »
There used to be a company called Telefix that sold fork braces for all makes of bike. They were in several parts, a pair of 2 piece clamps that fitted around the top of the fork bottom, & 2 straight sections that bolted between them with a little adjustment in the mounting holes for a good fit. They still come up at autojumbles.
I made my own for my last Reliant trike. Had a local engineer bore fork sized holes in 2 chunks of aluminium, with clamping bolt holes, cut them in half to form 2 piece clamps, then had another mate weld a flat bridge between them. Then spent weeks filing the ali to shape. Looks good though.
Here's a "Screamin' Eagle" Harley one on American Ebay for $25.
« Reply #10 on: May 21, 2013, 10:29:15 AM »
Just about visible in these pics, (the black bit above the front guard).
« Reply #11 on: May 21, 2013, 10:29:48 AM »
« Reply #12 on: May 21, 2013, 10:42:29 AM »
Or you could make a hooped one, like the one on my XS650. 2 flat plates bolted to the mudguard mounts on the inside of the fork legs, with 2 hoops welded to them, over the top of the tyre. Just about visible here. This one's just for show really & gives me somewhere to fix the guard to, but you could make it much beefier if necessary. Used a lot on American flat trackers.
skates
« Reply #13 on: May 21, 2013, 03:43:11 PM »
Found a firm that does braces but they have 4 different one for the cx500. How do I find out what forks I have?
digger06
« Reply #14 on: May 21, 2013, 03:44:58 PM »
do you actually need a mudguard on the trike,
you dont need em on bikes
