April 17, 2026, 04:40:19 AM
Trike Tech
Forks
Pages:
Topic: Forks (Read 5330 times)
Re: Forks
Reply #15 on:
May 21, 2013, 05:38:00 PM »
Use a vernier gauge to measure the diameter of the fork tubes & the top of the fork bottoms. They should be able to tell you which one you need then.
Re: Forks
Reply #16 on:
May 21, 2013, 06:15:29 PM »
If you are retaining the CX forks, then a good old steel brace, such as Mr. M suggested would be best, and the GL forks, which are the same as the CX's, do in fact use a steel brace/mudguard support, under the front mudguard as standard, so a similar item made from 6mm M/S should improve things, and you have a pattern to follow, simples!!!
Pages:
