March 04, 2026, 01:38:58 AM
Swap
Pinto motors
Topic: Pinto motors (Read 12272 times)
The North
Pinto motors
October 26, 2012, 10:02:18 PM »
2 Pinto motors both 1800s i am afraid 185s they have unleaded s type heads and are partially striped one has sump off the other head removed, all the major bits are there including new gaskets. Swap for WHY i have no use for them, and no plans in the future. What have you got.
Re: Pinto motors
October 29, 2012, 08:14:43 PM »
don't suppose you have a prop for a type 9 gearbox do you
I'm told they are the same for the sierra as the diesel.....
The North
Re: Pinto motors
October 30, 2012, 04:57:09 PM »
Sorry i do have a prop but need it, i am going from type 2s to type 9s in the marlins, they are slightly heavier and the gear ratios are not ideal but because i have gone 5.2 to 1 diff instead of 4.6 to 1 in the marina 575 axles used i gat a nice crawler tor trickling theough sections and 5th gear will give roughly the same speed with the lower rear end ratio as the direct 4th did with the 4.6to 1 van diff.
The North
Re: Pinto motors
February 17, 2013, 06:03:30 PM »
These are getting the weigh in if no one wants them, i may keep the heads but begining to wonder why
1800s are not 2 litres but they are not that bad on power with decent caruration cam and a little head work perhaps. and they have the same crank and stroke as a 2 litre so a straight bore out and new pistons gets you in effect a 205 2 litre engine that will just have 184 cast in to it.
madron
Re: Pinto motors
February 21, 2013, 11:26:20 PM »
how much do you want for the motors
Re: Pinto motors
February 22, 2013, 09:25:36 PM »
any carbs and manifolds ,,
The North
Re: Pinto motors
Reply #6 on:
February 23, 2013, 12:12:50 AM »
yes a dgas and a stock manifold just the one.
Re: Pinto motors
Reply #7 on:
February 23, 2013, 09:06:22 PM »
Quote from: The North on February 23, 2013, 12:12:50 AM
can you pm , me with a price etc,
