December 17, 2025, 02:55:22 AM *
Pages: 1 ... 36 37 [38] 39 40 ... 47
Author Topic: ,,EMILY,,  (Read 280836 times)
« Reply #555 on: June 15, 2013, 07:45:47 AM »
http://i468.photobucket.com/albums/rr41/spanners1964/emilytoday001_zpscd5fbc93.jpg
,,EMILY,,
but which does smokey burnouts?
« Last Edit: June 15, 2013, 07:47:49 AM by triker_Chewie » Logged
« Reply #556 on: June 15, 2013, 01:37:26 PM »
I hadn't realised just how petite she was! About the same size as a Moggy Minor pick-up?
dobber
« Reply #557 on: June 15, 2013, 10:21:19 PM »
,,EMILY,,
which one did you say was emily mike?
        can i have it in 20 Min's?
« Reply #558 on: June 15, 2013, 10:23:55 PM »
 Cheesy Cheesy Cheesy
« Reply #559 on: June 17, 2013, 12:07:55 AM »
well earlier this evening,,,after some,,adjustments,, Wink   i took ,EMILY, out  and after 3 or 4 mile,s of local roads ,,i took a good corner steady,, then i let het her ,,have it,,,,,,, Shocked ------------------- screech wheeee clunk,,, Shocked Shocked Shocked Shocked no drive  Roll Eyes Roll Eyes dry road and tooo many horses  Shocked. ?  ?
it was  the one time i had my phone ( i never take it anywhere anymore )  ,,EMILY, came home on a rope ,,,,,,,,,,,,,,,,,,,,,,,,,,,
i dropped the pan of the diff and the planet gears fell out in a number of bits ,,,,,,,,,,,,
                                  HAVE IT GOT A PROBLEM ?
« Reply #560 on: June 17, 2013, 09:30:51 AM »
What back axle is it Mike ?
oldmetalhead82
« Reply #561 on: June 17, 2013, 09:54:31 AM »
Time for somthin a bit stronger Mike? A narrowed Volvo axle perhaps ?
« Reply #562 on: June 17, 2013, 10:53:32 AM »
supposed to be a 2.8 capri ,,salsbury type,,
but now i,v bust it and seen inside it it doesn,t look heavy enough around the diff carrier ,,,its years since i had anything to do with them ,
« Reply #563 on: June 17, 2013, 11:31:16 AM »
axle details of the ,tag, which was still attatched ,
3.88,  8A19      P75A84004  CB
can anybody shed any light on what it actually is , Undecided
« Reply #564 on: June 17, 2013, 12:05:04 PM »
It's not a Capri 2.8i axle with a 3.88 ratio , they were 3.02 from memory ,part number on tag is actually P75 AB 4004  CB . 1975 signified first year of use in vehicle so it's a Mk 2 Capri from a low power model , 1600 ohc I reckon as 2 litres use a 3.7 ratio .Spider gears are always the weak link in Ford axles.
« Reply #565 on: June 17, 2013, 12:08:51 PM »
as i suspected  Cry i need to find something else then,,allthought i have a few escort and cortina ,english, axles about ,i may clean one of them up and use it as a, keep me going for now,,
« Reply #566 on: June 17, 2013, 02:42:51 PM »
They won't last with anything approaching a hard launch with that amount of torque. Sidestep a clutch on a Pinto with English back axle and kiss your spider gears goodbye , so won't survive long ,if at all Sad
« Reply #567 on: June 17, 2013, 02:48:07 PM »
kev,what axle would you recomend, it could do with being a bit higher geared aswell
« Reply #568 on: June 17, 2013, 02:55:36 PM »
Yep. been there done that.
How about  a Salisbury axle 3.54:1 from 110 Land Rover.
« Reply #569 on: June 17, 2013, 03:41:32 PM »
What sort of overall gearing do you want in top and how tall are your tyres?
