December 18, 2025, 01:28:38 PM *
Pages: 1 ... 11 12 [13] 14 15 ... 47
Author Topic: ,,EMILY,,  (Read 283865 times)
« Reply #180 on: March 18, 2013, 09:46:11 PM »
can you guys refrain from saying plugging away at emily please , i seam to have aquired a soft spot for her and am up for defending her honour  Grin
keep working on her spanners
O.K. i,ll just keep ,bangin away,, at her  Cheesy
« Reply #181 on: March 21, 2013, 08:46:30 AM »
Right what's this carb problem you mentioned elsewhere?
« Reply #182 on: March 21, 2013, 09:57:44 PM »
Quote from: kapri link=topic=11825.msg171235#msg171235 dat00e=1363855590
hi, kev its hard to explain but everytime i run it and warm it up it runs totally differant  Roll Eyes
i,m running it on the pipe work that came with it and it has a 3/8ths copper pipe from the tank to the mechanical lift pump and a return from the lift pump back to the tank but thats only 3/16ths (brake pipe size) i,m wondring if its part of the problem? ,as the mixtur tends to varie quite abit and the choke is an odd set up (odd to me   Roll Eyes as it works of vacume temp on the inlet manifold,, i,m sorley tempted to make a manual conversion (if only temporey)
the mixture variation is so bad at times that i,ve had black soot smoke out of the exhuast at on point,,, and bright blue flame,s at another ,
i can,t run it at the moment as i,v got other bits of it,, but before i run it again i,m going to clean the carb out and blow the jets through,
« Reply #183 on: March 21, 2013, 10:17:13 PM »
Hi Mike dont the fuel return pipe come off the carb and not the pump. Huh
« Reply #184 on: March 21, 2013, 10:26:33 PM »
hi terry , thats the unesual thing about it  its factory made return from the top of the mechanical pump but its a smaller bore than the carb feed , it seems to me as though the carb is getting to much or varieing fuel pressure ,, Roll Eyes
may try running it on a gravity feed and see if its any better ,,
« Reply #185 on: March 21, 2013, 10:51:55 PM »
Mike is this of any help not sure if its for your model carb.but may be of help in setting the carb up.
 http://oldcarmanualproject.com/manuals/Carbs/Rochester/2-Jet/Manual/index.html
« Reply #186 on: March 21, 2013, 10:57:13 PM »
thanks terry i,ll take a look at that,
just been on google trying to find a fuel pipe layout diagram,
the engine is an oldsmobil 260 v8 year 1976 approx and its out of a ,cutlass, or a,,delta 88,
« Reply #187 on: March 22, 2013, 09:10:08 AM »
Mike the third pipe goes to the fuel vapor canister. it has be some thing to do with fuel emission's you will need the manual to find out where they go
http://www.ebay.co.uk/itm/REMAN-1969-OLDSMOBILE-350-V8-AIRTEX-MECHANICAL-FUEL-PUMP-40665-/170974694350?pt=Vintage_Car_Truck_Parts_Accessories&hash=item27cee2cbce
http://www.ebay.co.uk/itm/120735225073?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
« Reply #188 on: March 22, 2013, 08:45:47 PM »
been busy last couple of days ,finished and fettled headers, and painted them , , mad gaskets and then fitted headers, droppd the oil cleaned out the sump (wasnt too bad)refitted ,changed oil filter (crosland PH25) refilled oil ,, changed plugs,,,,fitted,, flasher units,, fitted one set of wheel studs,,another set yet to fit,,fitted a wiper motor (hardest job of the week  Shocked ) most of the wiring is now in the cab,, then i,v been trying to sort out headlight and front indicator brackets,,,  Huh made two sts and then scrapped them both  Roll Eyes Roll Eyes just can,t get em right,,,,
got fan switch to sort out as the new fangleled ,expensive, controller is ,duff,,  Angry Angry and i can,t remember where i got it or what happened to the reciept Roll Eyes
and i,m stuck for a T piece for the oil pressure switch tapping so that i can run a gauge and an oil warning light ,
« Last Edit: March 22, 2013, 08:47:32 PM by spanners » Logged
« Reply #189 on: March 22, 2013, 10:51:27 PM »
Sounds like you've been busy Grin
« Reply #190 on: March 22, 2013, 10:56:23 PM »
pat (cooky) must think i,m ,playing away, the amount of time i,m spendin down the garage  Cheesy Cheesy
« Reply #191 on: March 24, 2013, 08:39:22 PM »
,EMILY, now has eye,s to see in the dark  Wink
Mendalot
« Reply #192 on: March 25, 2013, 03:53:31 PM »
What you on Mike?Huh   Wish I could get a large dose of enthusiasm like you got, so I can crack on with the Phaeton. Keep thinking I should be doing something, then this mysterious invisible force pulls me away from the workshop and right into my chair in front of the telly Undecided
« Reply #193 on: March 25, 2013, 09:44:22 PM »
I've got the exact same problem!
« Reply #194 on: March 25, 2013, 09:49:34 PM »
[/quote
spending lots of hours (over 10 today) but dont seam to be getting far,
its not ,,what i,m on,,, its i,m ,billy no mates,, so i bugger of down the garage ,, even the dog has got used to coming down the garage to tell me when its T,time  Cheesy Cheesy
