dr big750
« Reply #345 on: August 19, 2013, 03:19:47 PM » |
Do you want me to pop over on saturday to give you a lift with that engine  Did'nt say which saturday Alan
« Reply #346 on: August 19, 2013, 04:10:26 PM » |
Sure that would do,I'll have breakfast ready when you get here
« Reply #347 on: August 20, 2013, 07:16:21 AM » |
That looks like some pretty thick oil. Except when mounting in the frame (twice), my engine never left the ground. Figured if it's already on the garage floor it can't fall much further.
Is it a good idea to flush these engines,I know some don't like being flushed
« Reply #348 on: August 20, 2013, 09:59:03 PM » |
new sump fitted and gearbox back on ready to go back in the frame,also internal's of engine  A little progress  A little progress  A little progress
« Reply #349 on: August 21, 2013, 05:53:57 AM » |
I tend to go with the idea that flushing an engine can lead to particles that were safely stuck to internal surfaces floating around the engine, that draining may not totally remove . Personally, with an old engine that I'm not rebuilding, I would just fill with fresh oil, run it for a while( at least till running temp ), then do an oil and filter change.
« Reply #350 on: August 21, 2013, 06:08:04 AM » |
think i'll go with that idea ON ,if i get time over the weekend it will be up and running and off to get a petrol tank made
« Reply #351 on: October 19, 2013, 03:27:52 PM » |
well a little progress has now been made after a 2 month break .WOW time flies Got the trike back this morning having had a tank made at the local trike shop,well i say local but it's about 30 miles away.The good news is that the towing dolly performed faultlessly and we made it there and back with no issues what so ever  A little progress the tank is aluminium and is shaped around the axle and prop  A little progress it's mounted using straps and has a fuel sender in it for the gauge and uses an flip up filler cap  A little progress  A little progress  A little progress  A little progress so thats us up to date now time to get a push on,still need a front mudguard and to make a guard for the alternator and then is will be paint time i hope Anyone see anything I've missed so far please shout !
andyrennison
« Reply #352 on: October 19, 2013, 04:43:24 PM » |
Tank looks good, very neat place to put it. And the towing dolly didn't explode and end western civilisation after all, good one
« Reply #353 on: October 19, 2013, 05:08:01 PM » |
twisted
« Reply #354 on: October 19, 2013, 06:15:57 PM » |
Looking good scannerzer  .
andyrennison
« Reply #355 on: October 19, 2013, 06:23:15 PM » |
Where's your battery going Scannerzer?
« Reply #356 on: October 19, 2013, 06:25:28 PM » |
thanks Guys ,just need to get my finger out now and get it finished then move on to the next project
ps would you paint or polish the tank?
« Reply #357 on: October 19, 2013, 06:28:40 PM » |
It goes under the seat Andy,in here  A little progress don't seem to have one with it in place but i'll keep looking
« Reply #358 on: October 19, 2013, 06:31:58 PM » |
oh found it  A little progress
dr big750
« Reply #359 on: October 20, 2013, 02:47:31 AM » |
Is there 2 outlets for fuel? or is the front of the tank flat at the bottom to allow it to run to the outlet, from the pic it looks like an inverted U shape. Looking at a "professional trike builders" welding makes our welding look good Ed, lol. Get the engine running now, and get a you tube video of it moving so I can see my Frankenstein's monster alive
