April 22, 2026, 11:55:35 AM *
Pages: 1 ... 20 21 [22] 23 24 ... 36
Author Topic: A little progress  (Read 160736 times)
andyrennison
« Reply #315 on: July 03, 2013, 09:42:36 PM »
I've been thinking about your towing dolly. I think there will be very strong forces where it joins to the frame (as Pete said). Here is how I visualise it:
With the frame bolted to the dolly, you could visualise that as a single unit, a bit like a long plank of wood. Now imagine where the engine is positioned, right in the middle of the plank.
Imagine if you put both ends of the plank up on a stand. All the weight is now in the middle of the plank.
If you bounce one end of the plank (rear wheels on trike, or tow hitch going up and down) the centre of the plank with the engine on it will try to bounce more due to the leverage involved.
Your joint between the dolly and the frame is pretty much at that point of maximum bounce.
The front forks and wheel make a bridge from the front of the engine up the plank to near the towing hitch. That will stiffen the plank a bit over that section, but its effect will be negligible.
What it will do is add a pivot to multiply the downward force at the joint.
I'm sure it can work, just needs to be a beefy connection, maybe spread the load over 3 or 4 points of contact?
Of course I could be talking complete bo***cks Smiley
« Last Edit: July 03, 2013, 09:44:29 PM by andyrennison » Logged
« Reply #316 on: July 03, 2013, 10:01:45 PM »
yeh I'll have to do some figureing on this on this one Andy,Pete has similar concerns
« Reply #317 on: July 04, 2013, 02:48:46 AM »
perhaps if it hooked under the cross member
andyrennison
« Reply #318 on: July 04, 2013, 08:38:20 PM »
I would think over chewie, as the main deflection on the joint will be downwards wont it?
« Reply #319 on: July 04, 2013, 09:35:22 PM »
I'm still thinking about this, and i get your explaination with the plank but if we relaite it to a trailer with a single 2"box draw bar and accepting that it would have some form of springs on the wheels,that draw bar would be welded to the trailer in a similar fashion, if we sat an engine right at the front infront of the wheels would we expect the draw bar to bend or brake the weld?
thats what we thought when we built it and i'm still trying to get it straight in my head if we were right so still some thinking to do Huh
andyrennison
« Reply #320 on: July 04, 2013, 09:46:35 PM »
I take your point. Maybe you need to set it up and have a "monkey jump party" where we all come over and bounce on it SmileySmileySmileySmileySmiley
« Reply #321 on: July 04, 2013, 10:01:15 PM »
I like that idea ,when are y'all free Grin Grin
« Last Edit: July 05, 2013, 06:08:01 AM by scannerzer » Logged
« Reply #322 on: July 04, 2013, 10:02:41 PM »
As you say the trailer would have suspension, but the trike's a hardtail isn't it?  That's going to magnify every bump.
« Reply #323 on: July 08, 2013, 09:43:07 PM »
had a problem with the plate the brake idler was pivoted on in that it was twisting under braking
which left the pedal spongy,it had quite a bend in it.
http://i1056.photobucket.com/albums/t373/Eddie096/DF77CA10-67F1-42E7-8737-02E8122354C5-11616-000014DC3299C83E_zps4003d2f9.jpg
A little progress
3
http://i1056.photobucket.com/albums/t373/Eddie096/F2E94051-5EDF-4A51-9D34-1A7098CA501E-11616-000014DC3BE0903F_zps84cc347c.jpg
A little progress
so an upgrade was called for, 6mm plate instead of 3 and a gusset
http://i1056.photobucket.com/albums/t373/Eddie096/B95207F7-6EB1-427D-AF3F-66CA426FB77F-11616-000014DC43E0A6C8_zps9ed1d4c6.jpg
A little progress
http://i1056.photobucket.com/albums/t373/Eddie096/F7FC7C25-6EA8-4AE2-869E-2BA665302681-11616-000014DC685D913D_zpsd78659a5.jpg
A little progress
will this be strong enough or should i try and support the other end of the bolt as well
« Reply #324 on: July 08, 2013, 10:41:38 PM »
Id've thought if you manage to bend 6mm plate, you've got other problems -or arms like Popeye.
« Reply #325 on: July 09, 2013, 06:20:02 AM »
originally it was 3mm plate the replacement is 6mm  Grin
« Reply #326 on: July 12, 2013, 06:38:08 PM »
might not be much progress for a while...me welders packed up  Sad Sad Cry
think it the low voltage transformer,hopefully get it checked over the weekend
« Reply #327 on: July 12, 2013, 07:08:06 PM »
Chewie can probably sell you a new one -postage might be a tad expensive though, from Australia.  Tongue
« Reply #328 on: July 13, 2013, 01:41:07 PM »
Lol. Nah had to scrap all mine.
What's yours doing?
« Reply #329 on: July 13, 2013, 05:46:59 PM »
not feeding wire although the fan and power light are on I'll put a link to repair's when i jet a chance.
