November 10, 2025, 05:17:52 AM *
Pages: 1 ... 3 4 [5] 6 7 ... 14
Author Topic: "Met"amorphosis  (Read 86094 times)
phunkie hiboy
« Reply #60 on: June 02, 2013, 05:10:33 PM »
Lot of work, but worth while in the end, I think.
« Reply #61 on: June 02, 2013, 06:33:57 PM »
holy s**t, great work.
« Reply #62 on: June 02, 2013, 09:51:31 PM »
I'd missed when you cut the back off . Excellent work as always Chris Smiley
phunkie hiboy
« Reply #63 on: June 09, 2013, 09:17:47 AM »
Still more to cut off yet, Kev!!
So, still removing stuff, but seeing the light at the end of the tunnel for the rear end now.
Cut out roughly the boot floor. This is it next to the replacement going in.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture352_640_x_480_zps23915776.jpg
"Met"amorphosis
Then clean up the main “chassis” members ready for the replacement floor.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture353_640_x_480_zpsca72a914.jpg
"Met"amorphosis
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture355_640_x_480_zpscb3c88da.jpg
"Met"amorphosis
There are a couple of small repairs to carry out on the ends, and doing them now will make the whole job easier.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture356_640_x_480_zps8b3c9899.jpg
"Met"amorphosis
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture357_640_x_480_zpsa40de8f7.jpg
"Met"amorphosis
No more for a couple of weeks now, ‘cos we’re at Beaulieu next weekend.
phunkie hiboy
« Reply #64 on: July 11, 2013, 10:23:16 PM »
Now, the chassis end pieces have been replaced with good metal and the rear ˝ cross member spot welded back on.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture362_640_x_480_zps7dea4b94.jpg
"Met"amorphosis
As this car may well tow our Portafold caravan, I decided to add some strength to the rear. So made an internal cross member, out of 2mm wall 2” x 1” box. To that welded some turned spacers and side link pieces.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture363_640_x_480_zps9e4f1a2b.jpg
"Met"amorphosis
Now the ready to fit boot floor, with a coat of epoxy primer.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture365_640_x_480_zps06649d74.jpg
"Met"amorphosis
And spot welded into position.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture366_640_x_480_zps349fde9b.jpg
"Met"amorphosis
And now the battery box support sides and the rear spring hanger support plate. All the inside of box sections have been painted with red oxide.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture369_640_x_480_zpsfa29a38c.jpg
"Met"amorphosis
The exhaust manifold has been welded up, sanded off and polished.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture377_640_x_480_zps3df9c37b.jpg
"Met"amorphosis
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture376_640_x_480_zpseee95d5f.jpg
"Met"amorphosis
That’s all finished now, until final assembly.
The rear end bodywork has now been cleaned of all its surplus seams and has gone of to the media blasters, should have it back next Thursday.
« Last Edit: July 12, 2013, 06:19:46 AM by phunkie hiboy » Logged
« Reply #65 on: July 12, 2013, 07:19:52 PM »
That 'zorst is stunning Chris!
« Reply #66 on: July 12, 2013, 08:18:07 PM »
I was thinking the same, great workmenship
« Reply #67 on: July 12, 2013, 08:29:50 PM »
Beautiful!
phunkie hiboy
« Reply #68 on: July 12, 2013, 09:27:40 PM »
Thanks guys, still a loooooong way to go though.
dobber
« Reply #69 on: July 12, 2013, 10:54:23 PM »
just read this thread from the beginning... spot on, must have the patience of a saint.
        can i have it in 20 Min's?
phunkie hiboy
« Reply #70 on: July 13, 2013, 06:57:45 AM »
No, you just need to keep focused on the end result.
phunkie hiboy
« Reply #71 on: July 13, 2013, 08:07:25 PM »
Didn’t want to do anything too taxing or strenuous today (31 degrees in the end), so I decided to make an engine. This would move the project on and also get rid of the growing mountain of cardboard boxes that housed various parts.
So, start with a block that’s been checked and bored.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture379_640_x_480_zpsf4fa6025.jpg
"Met"amorphosis
And a crank that’s been ground, polished and balanced.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture380_640_x_480_zps5c04788d.jpg
"Met"amorphosis
Put them together, then add some pistons and rods.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture382_640_x_480_zps0a7bb101.jpg
"Met"amorphosis
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture385_640_x_480_zps601254b8.jpg
"Met"amorphosis
Add a Piper “automatic grind” camshaft.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture386_640_x_480_zpsd46a5340.jpg
"Met"amorphosis
Bolt on a new timing chain set and tensioner.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture387_640_x_480_zps8b92eea0.jpg
"Met"amorphosis
Fit an oil pump and the sump, and finally cover it all in BMC green.
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture390_640_x_480_zpsf4ab75e1.jpg
"Met"amorphosis
http://i781.photobucket.com/albums/yy95/phunkie_hiboy/metamorphosis/picture389_640_x_480_zpsdfe5292a.jpg
"Met"amorphosis
‘Nother little job done!!
« Reply #72 on: July 13, 2013, 08:15:16 PM »
Just like that!  No effort at all - apparently...
phunkie hiboy
« Reply #73 on: July 13, 2013, 08:20:43 PM »
Work up a little bit of a sweat, workshop's got a glass roof!!   Wink
« Reply #74 on: July 13, 2013, 08:33:24 PM »
to coin a phrase "I love it when a plan comes together"
