March 07, 2026, 06:08:32 AM *
Pages: 1 [2] 3 4 ... 19
Author Topic: speed is of the essence  (Read 66312 times)
kevsky
« Reply #15 on: August 16, 2012, 02:56:33 PM »
chop chop chopping
taking off the unwanted brackets
kevsky
« Reply #16 on: August 16, 2012, 03:03:07 PM »
new front end purchased but the stem dont fit the frame
so out with the bread knife a little more chopping blue tac the old on the new and bobs yer uncle
kevsky
« Reply #17 on: August 16, 2012, 03:06:03 PM »
rear panel for lights and number plate which by the way I fitted wrong way round as the lights sit in a reccess
kevsky
« Reply #18 on: August 16, 2012, 03:08:31 PM »
modified forks fitted
kevsky
« Reply #19 on: August 16, 2012, 03:16:41 PM »
brake plate template
gonna try one in 8mm
kevsky
« Reply #20 on: August 16, 2012, 03:18:38 PM »
disc on
kevsky
« Reply #21 on: August 16, 2012, 03:19:47 PM »
and caliper
« Reply #22 on: August 16, 2012, 06:55:31 PM »
You're fair flying along now Kev.
kevsky
« Reply #23 on: August 16, 2012, 07:40:29 PM »
not me mate I'm the gofor and cameraman
number 1 son is the builder and ideas guy
I/m just the experienced bloke  that makes  everything work out
« Reply #24 on: August 17, 2012, 12:41:37 PM »
Is it just the pic Kev or are those carrier plates real thin plate?
kevsky
« Reply #25 on: August 17, 2012, 03:36:53 PM »
very thin plate just a mock up to make sure they fit
hopefully the boy should have made some 6 or 8mm so they can be fitted this weekend
dobber
« Reply #26 on: August 17, 2012, 11:49:56 PM »
got a nice stance to it.
        can i have it in 20 Min's?
« Reply #27 on: August 18, 2012, 10:58:56 AM »
just noticed in the photo of brackets being chopped off with grinder, there seems to be a battery under the back of trike. sparks + battery = BANG!!!!!.... suggest you move it right out of the way.
build looking good, keep up the good work  Smiley
kevsky
« Reply #28 on: August 18, 2012, 11:27:44 AM »
6mm plates made with shim
8mm way too much
6mm with shim was a little too much
so 6mm fitted
kevsky
« Reply #29 on: August 18, 2012, 11:33:37 AM »
6mm seemed ok but the disc wouldn,t run true, after a lot of head scratching tightening of nuts slacking off of same ,the answer smacked me in the face ,we only had 2 studs in to hold the disc in place so popped in a couple more and hey presto running true
« Last Edit: August 18, 2012, 11:35:24 AM by kevsky » Logged
