March 07, 2026, 04:07:14 AM *
Pages: [1] 2 3 ... 19
Author Topic: speed is of the essence  (Read 66295 times)
kevsky
« on: August 05, 2012, 10:52:09 AM »
with the imminent closedown of the local dvla offices and testing stations the build of this guzzi is being pushed to the front of every other project so all hands to the pumps
kevsky
« Reply #1 on: August 05, 2012, 10:54:42 AM »
so this is how she was when laddio bought her
kevsky
« Reply #2 on: August 05, 2012, 10:57:44 AM »
shes running a reliant b axle without any lubricant in so its over to lads and lassies
what grade of the slippy stuff do we need and about how much
kevsky
« Reply #3 on: August 05, 2012, 11:02:39 AM »
a pair of new nova discs where purchased at the rather cheap price of 18 quid
but the fingy bits that bolt the wheel on had to have a tad shaved off em so they'd fit inside
kevsky
« Reply #4 on: August 05, 2012, 11:04:15 AM »
hardly noticable to the naked eye but doe,s help as can be seen in these before and after shots
kevsky
« Reply #5 on: August 05, 2012, 11:08:54 AM »
these will be in the machine shop tomorrow to be turned down so they fit snuggly
but what is the best way to do this
machine the disk or the hub
over to you guys
kevsky
« Reply #6 on: August 05, 2012, 11:14:04 AM »
went to the local scrappers and sourced a pair rear calipers off a golf but a cupla pins that hold the caliper to the carrier are missing and the price of these is new is more than he paid for the whole lot anybody got a cupla em floating about
kevsky
« Reply #7 on: August 05, 2012, 11:17:46 AM »
the beast naked
notice the rather substantial bit if tubing at the rear
kevsky
« Reply #8 on: August 05, 2012, 11:21:58 AM »
template for the rear light and number plate
not really sure if we added a little more masking tape and a coat of hammerite that it'd pass the ministry test but who knows
« Reply #9 on: August 05, 2012, 11:28:22 AM »
Hiya,
yup, as you've found, you need to knock the corners off the hubs to fit them inside the discs. Should still be enough "meat" around them to safely fit the wheel studs, but I've always welded the studs in from the back, just to be sure.
The raised centre of the hubs needs machining down slightly to fit the centre hole of the disc, (that's what centres the disc on the hub to make sure it spins evenly, rather than the wheel studs). Probably easier to do that, rather than opening the hole in the discs -the hubs are a softer steel. plus if you machine the discs, any future replacement ones will need to be machined too.
I've got one complete pair of spare calipers somewhere in the shed, but I'm holding onto them! Loony's Dad has a lathe in the workshop. He could probably machine some replacement pins. Couldn't whoever's gonna turn your hubs down do that for you?
« Last Edit: August 05, 2012, 12:13:20 PM by Manky Monkey » Logged
kevsky
« Reply #10 on: August 05, 2012, 11:31:19 AM »
never thought of that mate cheers
any thoughts on the axle oil
« Reply #11 on: August 05, 2012, 11:34:21 AM »
Castrol Hypoy 90Ep according to the Haynes manual.
kevsky
« Reply #12 on: August 05, 2012, 11:38:49 AM »
thank you very much sir
WAYNE999
« Reply #13 on: August 13, 2012, 07:40:30 PM »
The trike came to us with a reliant axle with a serial number starting with a B also it came without any brake backing plates drums bolts etc that's why the disc brake conversion seems a good idea so me being brought up in the metric era and most reliant being built in proper old English measurements can anyone tell me what bolts I need to fasten the conversion plates to the axle  Huh
one arm bandit
« Reply #14 on: August 13, 2012, 09:12:13 PM »
i got some for mine a few months ago but my memory aint the best,but i think they were 1/4 unf, someone might clarrify this first?? alternativly on most of my built i tapped out to metric where i could makes thing easier for us people with hair Grin
