November 11, 2025, 03:22:14 PM *
Author Topic: Rods little wagon project  (Read 2413 times)
« on: May 24, 2012, 02:13:14 PM »
Sorry,in no particular order Roll Eyes.....
This is the stub axle assembled onto the axle. Theres 2 cups,bent from penny washers to locate the spring,plus brass discs top and bottom to help with the wear. Although its only a short spring,its surprising how much it absorbs the bumps. It also helps to keep the steering reasonably tight. The springs are chopped from a long spring found inside doors closers. Valve springs could be used,but may be too long .
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2869.jpg
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2868.jpg
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2866.jpg
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2865.jpg
 General front view
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2864.jpg
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2863.jpg
 I use one wheel drive to the rear axle,this is the freewheeling hub.It creates a 'diff' effect and is easier to steer than a kart axle.Its basically a piece of tube welded to the hub plate.The tube is larger diam than the axle to accomodate a bush at each end of the tube. I
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2862.jpg
 Steering column outer tube
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2861.jpg
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2860.jpg
 This shows the downward facing hole to allow for oiling at a later date! The king pin just runs in the tube metal to metal. Ive used this method on several of these wagons with hardly any wear after a couple of years. I dont bother with ackerman angles etc,as the  speeds are so slow and it doesnt warrant all the setting up.
http://i956.photobucket.com/albums/ae49/HJody92/IMG_2870.jpg
Theres a lot of building hours in the front axle and steering.Hence why Ive shown the pics of it ,cos it seems to be the main thing that people cant work out ,and therefore give up after a while. It would be easier to get a complete kart front axle.
« Last Edit: May 24, 2012, 02:35:03 PM by ROD » Logged
« Reply #1 on: May 24, 2012, 10:03:04 PM »
I've no idea what you're building Rod, but it looks cool!
-how do you manage to dome a washer like that?
zakboy
« Reply #2 on: May 25, 2012, 08:17:37 AM »
I agree with MM it looks good Rod,.... but am a little baffled to what it is your making is it some kind of trailer  Huh
« Reply #3 on: May 25, 2012, 11:09:29 AM »
Well you pair must be blind,
It's obvious it's a motorized fridge Grin
zakboy
« Reply #4 on: May 25, 2012, 11:44:20 AM »
I see it now hunter.....i want one  Grin
« Reply #5 on: May 27, 2012, 06:25:11 PM »
You got it ! Grin
