« Reply #45 on: April 10, 2012, 10:06:17 PM » |
The Zenith down drafts were used on the earlier, 750cc engines weren't they? As far as I know, all the 850s used SUs.
« Reply #46 on: April 10, 2012, 10:27:02 PM » |
yep,,,
dragonwarrior
« Reply #47 on: April 10, 2012, 11:49:28 PM » |
that is what my engine is a 750cc
nabsim
« Reply #48 on: April 11, 2012, 12:45:10 PM » |
I thought that Andy but sure I have seen somewhere that the 850 could come with the Zenith as well depending what they had when it was being built.
« Reply #49 on: April 11, 2012, 01:44:26 PM » |
I thought I read that too somewhere!
« Reply #50 on: April 11, 2012, 01:51:54 PM » |
hi d-w. if you look on the right hand side at the back of your engine. if you were sitting on it. near the gearbox. just below the head you will see some letters and numbers some thing like 4h/85/10538 the 85 denotes its and 850cc some where on here it say what the others are for
zakboy
« Reply #51 on: April 11, 2012, 02:15:40 PM » |
A single 8 in the second part of the number will confirm its 750 and as terry pointed out 85 in the second part of the number is the 850 the 700cc is confirmed by c70 at the end of the number
« Last Edit: April 11, 2012, 02:17:33 PM by zakboy »
dragonwarrior
« Reply #52 on: April 11, 2012, 03:20:04 PM » |
it is a 750cc as it states on the logbook and also has the 8 its own on the engine
« Reply #54 on: April 12, 2012, 07:34:32 AM » |
I just knew you'd pop in on this one Pete!
dragonwarrior
« Reply #55 on: April 12, 2012, 11:17:16 AM » |
recieved the adapter this morning zak and i can't thank you enough it is perfect thank you so much dragon
« Reply #56 on: April 12, 2012, 01:11:29 PM » |
Woohoo..another hurdle over then!
zakboy
« Reply #57 on: April 12, 2012, 02:00:06 PM » |
no prob, just happy to hear you can make use of it
dragonwarrior
« Reply #58 on: April 27, 2012, 01:52:19 PM » |
need some get up and go my go seems to have got up and gone on holiday
« Reply #59 on: April 27, 2012, 02:10:47 PM » |
Know how you feel ,but remember every small job done on it ,is a little nearer the main goal! Just keep nibbling away at it!
