April 14, 2026, 08:27:11 PM *
Author Topic: Wheel adapters  (Read 12832 times)
« on: March 13, 2012, 08:54:19 PM »
Righto guy's, I purchased myself a set of 16 inch wires for the back of the pickup to go with the 17 incher front's.... Now I'm going to need  wheel adapters to get them to fit.. any idea's who can do this kind of thing?? cheers
« Reply #1 on: March 13, 2012, 09:57:30 PM »
bloke on rods an sods, cannot remeber his name though.....doh!!!
« Reply #2 on: March 13, 2012, 10:36:09 PM »
let me know when you remember mate  Wink Kiss
« Reply #3 on: March 13, 2012, 11:05:47 PM »
Doug, owner of Waldham Engineering in Basingstoke, Hants & member of the Guzzlers car club, could do them, but I don't think he'd be cheap.
Loony's Dad now has a lathe & milling machine in the workshop & is open to doing small one-off jobs. Getting hold of the material might be a problem though, unless you can supply it.
« Reply #4 on: March 14, 2012, 06:34:06 AM »
Search for Mallard Metal packs on internet metal by the inch.
« Reply #5 on: March 14, 2012, 08:37:26 PM »
There ya go Shaun -a good excuse to come up & see us.
« Reply #6 on: March 15, 2012, 12:54:48 PM »
cool, cheers guy's.. will check out the metal and get back to you MM...
« Reply #7 on: March 16, 2012, 12:42:35 AM »
do i read this correctly,
You get one 2ft piece of each size (Dia) 8 pieces in all 16ft, £43.39.   Shocked
http://www.mallardmetals.co.uk/MallardMetalPacksLtd_2012_MetalPacks.pdf
« Reply #8 on: March 16, 2012, 06:32:59 AM »
Yep you got it right.
« Reply #9 on: March 16, 2012, 11:34:15 AM »
Bit expensive them.
« Reply #10 on: March 16, 2012, 02:10:36 PM »
Not really I use Mallards for work and also when I need metal myself as you can buy as much or as little as you need.
Many places have minimum order either amount in cash or weight. RS normally supply 3 meters of everything so I'd rather buy exactly what I need rather than have loads of extra hanging around.
I'm sure there are cheaper places but not found  another supplier that sells by the inch.
pieman
« Reply #11 on: March 16, 2012, 09:57:14 PM »
I've just had to buy 3mtrs stainless tube more than I need as my local metal dealer only sells 6 mtr lengths. So that looks a good deal
« Reply #12 on: March 17, 2012, 12:35:46 AM »
I could probably by thay lot above for about £15 where i get my stuff from.
« Reply #13 on: March 17, 2012, 06:30:45 AM »
personally i'd get the length and keep the leftover for "maybe's"
one arm bandit
« Reply #14 on: March 17, 2012, 10:50:43 AM »
or incase you balls it up, more comonly referd to as " i have ballsed it up i just thought it would look better this way" Cheesy
