November 13, 2025, 02:12:25 AM *
Author Topic: what antifreeze  (Read 7527 times)
« on: February 05, 2012, 01:10:57 PM »
with all this cold weather were getting. made me think about what anti freeze i can use in my trike.
looked in the work shop manual and is says 50/50 of distilled water and ethylene glycol anti freeze.
well as all the safety hazards. what can i use on an engine thats 30 years old
« Last Edit: February 05, 2012, 01:12:42 PM by terry t » Logged
Bus Boy
« Reply #1 on: February 05, 2012, 01:16:20 PM »
i would have thought that normal , off the shelf stuff should do the trick, mixed as per instructions of course!
« Reply #2 on: February 05, 2012, 01:42:25 PM »
Maybe ye olde AA can assist
http://www.theaa.com/motoring_advice/general-advice/antifreeze-coolant.html
An alternative to distilled water (and cheaper) is to knock off the excess ice from your freezer, and use the melt water.
Its just that tap water can have 'extras', and these can be detrimental with respect to corrosion. (drink, of course!!, but put it on your motor's coolant system!!!  Grin)
Bus Boy
« Reply #3 on: February 05, 2012, 02:27:46 PM »
back in the day i was always advised to use water from a water butt....i.e rain water!!!
« Reply #4 on: February 05, 2012, 02:40:26 PM »
cant use the ice from the fridge/freezer its one of them frost free Eco things  Grin Grin
some one said use the water from the tumble dryer.empty the water that collects in the water drawer into a container
RODeo
« Reply #5 on: February 05, 2012, 02:53:09 PM »
Hmmm...been thinking about this too..Im sure that when I had aly blocked vehicles years ago,there was some special antifreeze for them.
« Reply #6 on: February 05, 2012, 05:14:48 PM »
As far as I'm aware, antifreezes used to be methanol based in the days when most car engines didn't have ally heads (ie cast iron was the norm).
Back then, if you had an ally head, then you needed a 'special' antifreeze as methanol wasn't too clever with ally..
Nowadays with most engines being ally, the antifreeze is designed to be compatable and is ethylene glycol based.
« Reply #7 on: February 05, 2012, 05:20:00 PM »
may be thats why they say 50/50 mix. 30 years ago not many ally engines or heads about  Huh
« Reply #8 on: February 05, 2012, 05:30:37 PM »
...mmmm... maybe that's up for debate.....
The freezer ice is made by freezing the moisture in the air, so has 'no additives'.
Where does the water come from that is found in the tumble drier drawer?
If its from the moisture from the clothes that re being dried, we're talking clothes that have grubby, gone through tap water, detergent and maybe fabric conditioner, which have then been heated, with the residue then being condensed. (trying to get my head around it)  Undecided
Distilled water comes from boiling the tap water (with all is extra bits) so steam is evolved (pure water in gas state),which is then condensed, giving pure water (liquid state) and leaving all the 'impurities' in the boiling pot.
Remember when used to do this at school we always discarded the first amount to ensure good quality for the rest.
« Reply #9 on: February 05, 2012, 05:40:01 PM »
The dilution factor is proportional to the level of temperature protection you require (the more antifreeze, the lower the freezing point because you're diluting the water), however, there is a small price to pay, in that the stronger the solution in your engine, the slightly less efficient the solution is at transferring heat.
No need to panic, chances are none of us would ever notice it though.
Another thing to bear in mind about 'antifreeze' is its also got a higher boiling point than water (due to the ethylene glycol), as well as inhibitors,
http://en.wikipedia.org/wiki/Antifreeze
« Reply #10 on: February 05, 2012, 05:46:56 PM »
 Huh Huh so when i boil the kettle to make a drink. if i then pour whats left in the kettle into a container that's then is distilled water.yes
thebigdogsix
« Reply #11 on: February 05, 2012, 06:05:22 PM »
No  Smiley
« Reply #12 on: February 05, 2012, 06:22:13 PM »
No  Smiley
oh  Grin
i will have to make my own antifreeze and distilled water hic  Wink  Roll Eyes
http://www.ebay.co.uk/itm/COPPER-WHISKEY-STILL-MOONSHINE-STILL-DISTILLERY-MADE-ALPHAMOONSHINER-/290666425160?pt=LH_DefaultDomain_0&hash=item43ad11ab48
« Reply #13 on: February 05, 2012, 07:07:33 PM »
bought 20 litre,s of ante freeze on friday £30 delivered
« Reply #14 on: February 05, 2012, 10:26:42 PM »
T'other way round - If you condense the steam from the kettle, that the distilled water. All the kak remains in the kettle.
Kinda make ya want to rinse out the kettle every now and then tho...........  Wink
