November 13, 2025, 03:54:57 AM *
Pages: 1 [2]
Author Topic: what antifreeze  (Read 7533 times)
RODeo
« Reply #15 on: February 10, 2012, 09:41:51 PM »
Just found a new container of a/freeze in the garage. Bought it when I had my vw. The label says its formulated for aly engines,and the mix is 25% for temp down to minus 8 . One thing that hasnt been mentioned about a/freeze,is that it will find the leaks,(poss no more than water does),but it shows more,leaving a deposit when it dries.
Bus Boy
« Reply #16 on: February 12, 2012, 03:42:44 PM »
a few moons ago we tried out some new fangled system at work to flush out the cooling systems on the buses, got all the chemicals,the wiz-bang washing machine-like contraption to do all the neccessery cleansing , connected up ran the system through its paces......voila, spanking clean coolant system......................................but.................it leaked like a leeky thing wiv holes in!
problem is when its cleaned, all the lime scale & corrosion in the system thats blocking up all the hoses, ports etc. is also what stops an old system from leaking!!!!!!!
brilliant!!!!!!! Undecided Cheesy Cheesy Wink
« Reply #17 on: February 12, 2012, 08:29:08 PM »
 Roll Eyes  been there  many years ago   Shocked  on buses tooo Cheesy
pieman
« Reply #18 on: February 13, 2012, 12:00:28 PM »
not all antifreeze is concentrated  you can buy ready to use so no need to boil a kettle or chip the ice from the freezer, it does mean you cant run a stronger mix if you live in the Scottish highlands
Pages: 1 [2]
