November 11, 2025, 10:47:56 PM *
Pages: 1 2 [3] 4 5 ... 9
Author Topic: ELECTRONIC IGNITION ; A HOW TO CONVERT GUIDE  (Read 40506 times)
« Reply #30 on: January 21, 2012, 03:17:31 PM »
Taz wrote a bit on posting photos on the forum here:
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=4469.0
and Nabsim added more info here:
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=6349.0
RODeo
« Reply #31 on: January 21, 2012, 03:30:06 PM »
If the dizzy body is hitting something as you turn it to get it to fire,this is probably because the body is in the wrong place to start with. I had this when I first set mine up last year,I had the vac bit round at the front near no1 lead..I ponced around for hours getting nowhere,almost gave up! Try putting the distributor in at a different (window)after setting the engine up for static timing.Very roughly speaking the vacuum 'bowl' should be at 90 degrees to the eng. block to start with. Is this what is hitting the leads?Apart from moving the dizzy,this will mean moving the plug leads round in the cap,probably one position round. .In summary....static time engine with no1 lead coming up to fire with the vac unit facing away from the block.Hope this helps mate
« Last Edit: January 21, 2012, 03:36:46 PM by RODeo » Logged
skates
« Reply #32 on: January 21, 2012, 03:55:13 PM »
ok here goes. the metal where the clips hold on the dis cap is hitting the spark plug cap so it wont turn any more. plus iv got here running but not right. also when she is running and i take a lead off she starts sparking at the coil
RODeo
« Reply #33 on: January 21, 2012, 04:25:25 PM »
If the clip is hitting as you describe,then I reckon the dizzy needs repositioning as I explained previously.My clips are roughly front and rear of the cap.Sparking where at the coil? Which lead are you taking off?
« Reply #34 on: January 21, 2012, 04:31:28 PM »
coils, damp or cracked ,,,,,,,,,
skates
« Reply #35 on: January 21, 2012, 04:39:37 PM »
i bloody well hope not. bought the whole kit with a new coil
RODeo
« Reply #36 on: January 21, 2012, 04:46:53 PM »
Heres how mine sits,it is adjusted and running correctly.just gone out there to take this pic,hope it helps mate
« Last Edit: January 21, 2012, 04:53:47 PM by RODeo » Logged
« Reply #37 on: January 21, 2012, 04:47:15 PM »
poor insulation on the low tension connections then,,
RODeo
« Reply #38 on: January 21, 2012, 04:51:35 PM »
He hasnt said where it is sparking from??
skates
« Reply #39 on: January 21, 2012, 04:56:04 PM »
its sparking from the red power lead the came with the kit. its sparking from the +termenal to the coil casing
RODeo
« Reply #40 on: January 21, 2012, 05:05:08 PM »
and which lead are you taking off for this to happen?
skates
« Reply #41 on: January 21, 2012, 05:16:30 PM »
if i take off any ht lead of any plug while the engine is running it starts to spark on the red wire from the ignition that goes to the + connector on the coil
RODeo
« Reply #42 on: January 21, 2012, 05:22:47 PM »
Not knowing much about the working difference between elec ign and points,Im not sure about this. maybe the elec ign causes it to do that?sorry cant be more helpful dude. Is there a good connection of wire to spade terminal at the coil? I crimped one today,looked ok,but wasnt making contact correctly!
« Reply #43 on: January 21, 2012, 07:16:08 PM »
check the terminals on the coil and make sure there no oil or grease on the coil.have a good look at the coil top to see if there any sign of cracking.make sure all wire are tight
« Reply #44 on: January 21, 2012, 07:31:11 PM »
You did refit the earth wire in the distributor ?
Have a wee look at the distributor again .
Suck on the vacuum tube end on the flying saucer and check that the points plate moves .
Take the distributor out if you cannot get access to suck .
If the end of the flying saucer lever is not located in the points plate peg on the underside of the base then the points plate will not be in the correct position relevant to the rotor /pickup .
When you do start it , make sure that the vacuum pipe is connected from the flying saucer to the carb .
