January 19, 2026, 10:47:42 AM
Bike Tech
fork tube swap
Topic: fork tube swap (Read 3273 times)
fork tube swap
February 15, 2010, 08:27:02 PM »
I reckon I probably know the answer to this but, would I be able to fit a set of forks with a tube diameter of 37mm in place of a set with a 33mm diameter?
The reason I ask is the set of forks from the Hartford sat in my garage would look great on the CJ, they have discs and calipers, wire wheels, good tyres and everything!
had a quick look at the rear one, and that might swap too!!
Last Edit: February 15, 2010, 08:51:31 PM by Clive
Re: fork tube swap
February 15, 2010, 08:33:01 PM »
Wont be a problem, assuming of course you swap the yokes too, and thats where your problem could start, not only have the steering pins got to be the same length but the outer bearing diameters need to match too.
Re: fork tube swap
February 15, 2010, 08:47:00 PM »
Knew someone would say that!!!
Any idea how I could compare them without taking them both apart?
Re: fork tube swap
February 15, 2010, 10:33:34 PM »
Most steering stems are a press fit into the bottom yoke. You may be able to fit the stem from one into the yoke of the other. Or have a new stem machined.
Re: fork tube swap
February 15, 2010, 11:45:47 PM »
Unless you are able to get the bearing dims. from elsewhere, you will have to strip the steering head to measure the bearings. Once you have the dims. you may well be able to match up a set of taper rollers to suit, I have done so on many occasions. The stem length you can obviously obtain without the need to strip the steering head. Morrag
Re: fork tube swap
February 16, 2010, 07:43:59 AM »
Thanks all!!
Sounds too difficult for me, so I'll give it a miss!
