« Reply #45 on: March 07, 2010, 03:33:14 PM » |
Completely re-built the wiring loom today! I love doing this, it's probably my favourite part of a re-build, just something satifying about creating one, from that jumble that is a wiring diagram!  Got some filler on the tank too! A quick question though. I've got some different bars on their way to me, but need to drill some holes in them! Any tips on trying to drill holes in a curved stainless steel surface? (I have no drill press) Clive
« Reply #46 on: March 07, 2010, 04:27:28 PM » |
You only need to stop the drillbit from slipping, a couple of layers of masking tape (if you have any  ) will allow the bit to grip
« Reply #47 on: March 11, 2010, 11:29:50 AM » |
Made some progress this morning with the bike! Coils back on, front brake caliper, rear brake pedals, kick start, headlight casing, speedo cable, and then..................
offered up the exhaust, went to put the collars on the bolts, and they needed some 'persuasion', realised, I then needed to take them back off as they weren't sat quite straight, and they're stuck fast!! There's not enough room to get behind them to give them the same persuasion back off!!!!
Any ideas as to how I'm can get these back off??
« Reply #48 on: March 12, 2010, 09:03:23 PM » |
Well, got it back off, with some wrecking bar action!!  Front of the engine now needs another lick of paint! A couple of pics showing progress!  Clives Cafe Racer  Clives Cafe Racer  Clives Cafe Racer  Clives Cafe Racer  Clives Cafe Racer Clive
« Reply #49 on: March 12, 2010, 09:05:40 PM » |
Didn't realise how dusty it had got!!
« Reply #50 on: March 12, 2010, 09:13:33 PM » |
It's looking very tidy Clive.
« Reply #51 on: March 13, 2010, 04:57:02 PM » |
Thanks buddy  Had a productive day today!! New handlebars were drilled, re-wired, and mounted on the bike! That then meant I could re-fit the headlight and re-connect all the wiring! Couldn't resist then connecting a spare battery I had kicking about and checking all was good.............................and it was!!!! Even the high beam indicator that I'd put on the headlight cowl (can be seen in the pics between the dials) Chuffed to ****!!! Was slightly confused at first when the main beam, high beam, horn worked on the first click round on the ignition, but not the side, or tail light. These worked on the second click, but not the ones that worked before  Now realise, and I hope I'm right and stand to be corrected if need be, that the side light and tail light are on permanently when the bike is running, and the rest then take their power from the charging system!! Really not much left now, mainly bodywork and paint (tank, front mudguard). Still need to get a clutch cable, throttle cable, battery, banjo bolt pressure switch, and wait for my seat to arrive!!!! Clive  Clives Cafe Racer  Clives Cafe Racer
voodoo
« Reply #52 on: March 15, 2010, 10:59:07 PM » |
Custom Paint Spraying... English by Birth..Biker by choice.... Growing old is inevitable...Growing up is optional....
« Reply #53 on: March 16, 2010, 07:22:54 AM » |
Cheers buddy, although I'm sorted for handlebars for this build, you can never have too many handlebars!!!  Did a bit more investigating on the lights thing. The second click is definitely a 'park' position as the key can be removed. I reckon, when the engine/alternator kick in, the side/tail lights will then work!?!?! Only time will tell!! Clive
cunningplan
« Reply #54 on: March 16, 2010, 08:05:23 AM » |
« Reply #55 on: March 16, 2010, 01:45:01 PM » |
Not really buddy, but always good to have as reference, cheers!!
« Reply #56 on: March 17, 2010, 01:05:29 PM » |
Right, studied the wiring diagram, and switch diagrams long and hard, and reckon it's okay! Will give it another go with the new battery, which should be here by the time we get back from Berlin on Sunday!!
Hagar
« Reply #57 on: March 17, 2010, 05:03:16 PM » |
time we get back from Berlin on Sunday! SSSHHhhh ....... you never know whose listening ...  .. Hagar ..
" When you have to kill a man , it costs nothing to be polite. " .. Winston Churchill
cunningplan
« Reply #58 on: March 17, 2010, 06:25:11 PM » |
Same here  , but I have to work with it every day (Only the car these days)
madron
« Reply #59 on: March 17, 2010, 07:34:15 PM » |
hi clive made mould and making your seat tonight will send you a pic tomorrow to confirm its the right one
