All the tyres came without wheels, had to buy them separately. Just to add insult to injury, Andy, there was also two rear slicks in the bundle as well.
http://www.ebay.co.uk/itm/301189940423?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649Click on the link a check it out!!
I thought I’d better get the fixings for the hubs sorted so I was ready to fit them as soon as the adaptors were done.
First the axle tubes were tapped down the middle.
Another little Phunkie project
The “stud” cut to length.
A hole drilled in the axle and the stud screwed in to the right depth.
Rosette welded in the hole.
Then the weld cleaned up.
This obviously done on all four corners.
Picked up the adaptors at lunch time as promised.
So now we have all the bits that just need assembling.
The adaptors were slid onto the axle.
Hub securing nut fitted and tightened.
A hole drilled and tapped through the adaptor and into the axle.
Then secured with a grub screw coated with Loctite.
The hub was then slid over the spindle and secured.
Same proceedure was carried out on all four corners.
Now it’s the time to fit the wheels to the hubs and ……….. Voila.
Enough for one day I think!!
