November 04, 2025, 12:48:10 PM *
Author Topic: Twist grip gear change  (Read 6173 times)
« on: July 11, 2012, 09:56:15 PM »
Have any of you seen the pst on the NABD forum where they are using a push pull twist grip note left handlebar to operate a bike gearbox gear change (as old scooters)?
This is what we are going to try for Shane but just wondering about getting clutch lever to move with the twist grip same as the scooters did. Anyone know of anything that has a combined twist grip and lever?
« Reply #1 on: July 11, 2012, 10:05:40 PM »
rob a vespa  Wink Wink
skates
« Reply #2 on: July 12, 2012, 10:32:00 AM »
or a lammy
« Reply #3 on: July 12, 2012, 12:31:15 PM »
Never even thought about doing that. The scooter I remember with this setup was in 1969 so I doubt there are many of them kicking about now, anyone know when they changed or do they still have the left twistgrip change? Was it Vespa's as well?
« Reply #4 on: July 12, 2012, 12:53:22 PM »
Just thought a bit more about this, the scooter I rode that had this setup was an Li 150(?) and if my memory serves correctly it wasn't a straight push/pull up and down but had positions for the gears. Can someone tell me if I have that wrong and a scotter setup would work for a 5 speed bike change (i.e. straight up/down returning to same position)?
« Reply #5 on: July 12, 2012, 02:14:44 PM »
try calling a MEL.S,  ==andrew mellands at fernilee see whats lying about, Wink you never know  Wink Wink
one arm bandit
« Reply #6 on: July 12, 2012, 03:08:49 PM »
im not sure about the clutch aswell but using a twin cable twist grip could do up motorbike gears as the lever returns to central position after each change, it would only require a bracket to hold the cables and somthing to attach the cables to the gear lever. its a bloody good idea that nabs Wink
stumpy
« Reply #7 on: July 12, 2012, 04:27:28 PM »
its a big load of hassle cables stretch you will spend your whole life adjusting it i got a couple of spare klick o tronik gear shifters buttons on handle bars easy to fit never go wrong currently well over 700 pounds to buy may sell one if it helps pm me with your phone number .... you could pay quite a bit for scooter clutch / shifter and its a crock of s**teeee compared to mine i use it on my bike had one fitted to last 15 bikes ive owned never missed a beat as seen at basingstoke
hornet6
« Reply #8 on: July 12, 2012, 09:38:03 PM »
When my brother had his first moped back in 1972,3 ....that also had a clutch and twistgrip gear selector. It was one of those bright yellow puch's,with a steel pressed frame,and a yellow and chrome tank. Undecided Undecided
no projects ever finished
« Reply #9 on: July 13, 2012, 12:39:09 PM »
Hold on, slow down, the push pull throttle isn't my idea or design, I saw it on the NABD forum here http://forum.disabledbiker.co.uk/viewtopic.php?t=5410 thought it a great idea and well worth a go.
I know a kliktronic would be a better option but the money isnt there for one of those. Know what you are saying about cable stretch Stumpy but if we get some decent cables we should be able to minimise that (cant help thinking of those cables they used to steer that Gears of War trike).
If you look at the link I have posted you will see the guy has done a few of them okay
« Reply #10 on: July 13, 2012, 01:34:51 PM »
if you go the cable route  ,nabs,,  cable - tec  at sutton in ashfield  are the very helpfull chaps.. we used to get 12 metre gear selection cables made by the for the  duple 425 coach,s.. practically nil stretch in 12 metre,s
madron
« Reply #11 on: July 13, 2012, 06:06:08 PM »
i converted an intruder to lambretta left bar twist gearchange and clutch lever i used 2 clutch cables and had to mess about with the length of the linkages to get it right and he said it took a bit of getting used too if i remember it cost £65 brand new from a racing scooter place at edlington near me if wanted will see if they are still going and get a number for you
« Reply #12 on: July 13, 2012, 06:27:34 PM »
Madron did the scooter gear have positions for gears or was it straight up down? Think with using it you have answered my question anyway cos it must have worked Smiley
If you have a name or number it may be helpful, we haven't started nothing yet but knowing there is a contact is always useful
skates
« Reply #13 on: July 13, 2012, 08:07:17 PM »
there are loads of scooter parts out there mate
Item number: 280693134872
voodoo
« Reply #14 on: July 13, 2012, 08:45:58 PM »
One of the early Puch mopeds (the ones that look like a bike and not a scooter ) has the twist grip gear change I had one about 25 years ago and was real fun learning to use the twist after foot change...not sure of the model but they are Yellow & chrome bikes...hope this is of some use?...Voodoo....
Custom Paint Spraying...
