May 15, 2026, 06:44:45 PM *
Author Topic: machining work  (Read 3250 times)
« on: July 04, 2011, 06:31:52 PM »
can any give me a price to machine these up for me.i cant get bearing for my forks to fit the headstock.
bottom bearing cup.  top bearing shim.  top hat dust cover.
http://i51.tinypic.com/11gj5fk.jpg
machining work
« Reply #1 on: July 04, 2011, 06:40:51 PM »
Wouldn`t it be easier to replace the pin?
« Reply #2 on: July 04, 2011, 06:49:26 PM »
the yokes don't seem to be solid enough. around the pin area to put a bigger pin in.it would need to be a 30 or 35mm pin
the forks are of a gpz600r
RODeo
« Reply #3 on: July 05, 2011, 04:35:40 AM »
terry...........I recently bought some bearings for mine,that no one else seemed to have, from a place on the 'net,think it was called motorcycle bearings. v.g. service and cheap and VERY helpful too, I'll try to find the address...........
 Here you go.Im 99% sure these are the people.......Marksman Bearings  01252 345 455 They also do the bearing seals. If they havent got it listed give them a ring ,thats what I did,and after phoning about 6 other suppliers ,they sorted it for me.Hope you have some success
     Rod
« Last Edit: July 05, 2011, 04:48:15 AM by RODeo » Logged
« Reply #4 on: July 05, 2011, 11:12:24 AM »
I have tride my local brr bearing shop and they said that size is not in there catalogue.the main problem is the head stock was custom made
this is the yoke on the headstock. with the nut to hold the bearing in place done right up hand tight.you can see its about 20mm longer.
« Reply #5 on: July 05, 2011, 11:23:02 AM »
can i ask a silly question,,
what diameter are the fork legs ?      that bottom yolk looks familier..
« Reply #6 on: July 05, 2011, 11:40:58 AM »
37mm there off a kawasaki gpz600r
RODeo
« Reply #7 on: July 05, 2011, 11:53:25 AM »
Cant see any pics terry. Is the 20mm gap you are talking about going to be taken up by the extension you showed on your drawing (saw it earlier,cant see now!)
« Reply #8 on: July 05, 2011, 12:33:57 PM »
Hi ROD the drawing and photo are still there.yes the extention bearing cup holder is to make up the different in sizes
« Reply #9 on: July 05, 2011, 01:01:47 PM »
You could turn down the end of a bigger pin so that it would fit the yoke.
