May 15, 2026, 07:49:34 PM
Trike Tech
headstock
Topic: headstock (Read 2374 times)
headstock
July 03, 2011, 04:38:34 PM »
is there a sort of standard size for the headstock. mine is 165mm long x 63mm dia. to take 55mm x 35mm bearings.
RODeo
Re: headstock
July 03, 2011, 04:47:32 PM »
One thing to remember when sorting out the headstock..make sure that there are a couple of cut outs in the 'shoulder' where the bearing sits,to allow for a drift to be passed down from the opposite end of headstock and be placed in the notch to knock out the bearing outer ring .I didnt ,and had to spend quite a while very carefully cutting out the outer ring with a dremmel and a cutting wheel. I broke about 30 wheels making several cuts, before it finally came out!
Rod
zakboy
Re: headstock
July 05, 2011, 01:28:23 PM »
Quote from: terry t on July 03, 2011, 04:38:34 PM
is this the size bearings your looking for
Re: headstock
July 05, 2011, 02:29:38 PM »
Quote from: zakboy on July 05, 2011, 01:28:23 PM
Hi zak yes that is the bearing size.i know were i can get some.its the yokes stem to fit the 35mm part i having trouble with
