November 01, 2025, 04:55:49 PM *
Author Topic: q plate????  (Read 1305 times)
freedomknight
« on: May 31, 2011, 09:58:49 PM »
if i have q plated cx trike and want to register it with reliant engine instead am i likely to hit any problems paperwork dvla wise ??
« Reply #1 on: May 31, 2011, 10:40:30 PM »
I would think you would just notify the change same as any other change to a vehicle.
zakboy
« Reply #2 on: May 31, 2011, 11:11:58 PM »
i think if you are saying you are thinking of replacing the cx engine with a reliant engine on the cx then you would need to notify dvla of the change,dvla then may request a engineers report from a garage to say the engine had been fitted corectly, if you say the work as been done by your self then they may request a dvla inspection at your local dvla office once it is established it is fitted corectly the the log book will be amended showing the changes, zak
« Reply #3 on: June 02, 2011, 12:42:05 PM »
Now I may be wrong but I reckon with a Q plate you just need to send changed engine number and cubic capacity. Fuel type if that changes as well
WAYNE999
« Reply #4 on: June 02, 2011, 06:14:57 PM »
it should just be a matter of sending in change of capacity and new numbers to swansea it seems to be easier to alter something on a Q than something with an age related plate
freedomknight
« Reply #5 on: June 04, 2011, 07:45:35 PM »
thank you all for help saves me buggering the paperwork up
