May 18, 2026, 10:12:11 AM
General Tech
offset
Topic: offset (Read 2689 times)
klogan45
offset
May 30, 2011, 05:50:50 PM »
Ok so i'm going to ask a real dumb question. I know what pcd is so no problem there but what is the offset of a wheel?
Thanks
Regards
K
Re: offset
May 30, 2011, 05:59:28 PM »
The distance from the mounting surface in the middle of the wheel, to the outside edge of the rim. For example, deep dished wheels have a lot of offset, compared to most modern wheels which are almost flat fronted, so have very little offset.
klogan45
Re: offset
May 30, 2011, 06:06:43 PM »
Oooooh I get it. Thanks Andy, much appreciated.
Regards
K
ByzMax
Choppit
Re: offset
May 31, 2011, 09:00:52 PM »
The offset is calculated from the centre of the wheel.
so you have a positive or negative offset depending on where hub is place within the wheel
http://www.choppit.co.uk
klogan45
Re: offset
June 02, 2011, 09:23:09 AM »
Thanks Andy and Byz, I get it now.
Regards
K
