March 05, 2026, 12:03:46 PM *
Pages: 1 ... 48 49 [50] 51 52 ... 70
Author Topic: hillman superminx 1962  (Read 353501 times)
« Reply #735 on: April 19, 2013, 10:17:48 PM »
Yeah, seems for every one item I cross off mine, I add another three on!
« Reply #736 on: April 20, 2013, 06:04:48 AM »
the list is only ten items long!!!  but you know lists lie!!!
Cheesy
Only three! Things are getting better then Wink
« Reply #737 on: April 20, 2013, 05:54:18 PM »
taken a lot off work today to get to this point!!!
« Reply #738 on: April 20, 2013, 06:16:02 PM »
That's cleaner than any car I've ever owned!
« Reply #739 on: April 20, 2013, 06:27:21 PM »
not cleaned anything, just put things back as they layed on back seat!!!
had to fill lots of holes, and changed shape of gearstick.
i would like to have new carpets but budget won't stretch at moment.
« Reply #740 on: April 20, 2013, 06:28:45 PM »
going to put a bigger throttle pedal in as my boot nearly goes over the top!!!
« Reply #741 on: April 20, 2013, 06:51:30 PM »
 Smiley Cast aluminium Moon pedal? Or Marshal drum pedal?
« Reply #742 on: April 21, 2013, 08:32:14 PM »
had a little time on it tonight, connected some wires up, changed a fuse and i've got all electrics working apart from main beam on one headlight which happens to be a sealed beam. amazing everything worked though!!!
« Last Edit: April 21, 2013, 09:08:26 PM by poprodder » Logged
« Reply #743 on: April 21, 2013, 10:37:39 PM »
Woo hoo! C'mon, let's take her for a spin!
« Reply #744 on: April 22, 2013, 05:29:25 PM »
i want to!!! think the mrs will be first taking it for mot(hopefully next week sometime)
« Reply #745 on: April 22, 2013, 09:38:21 PM »
not much progress tonight as did'nt get to do any work till nearly 8pm so could'nt make much noise. got cowling fitted round steering column, which was lucky it fitted as its at a different angle,  sorted steel out for brake flexi supports, and hunted for washer bottle holder without success. also found out i've got wrong wiper blades, they don't fit onto the arms, but i've got a plan to get over that(fingers crossed) as they're stainless an not cheap.
« Reply #746 on: April 22, 2013, 10:02:34 PM »
Getting there though Chris.
« Reply #747 on: April 22, 2013, 10:05:10 PM »
yep, the mrs just come home and said i should off carried on an bollox to the noise!!! Shocked
« Reply #748 on: April 22, 2013, 10:42:43 PM »
« Reply #749 on: April 23, 2013, 08:48:44 PM »
well i made some noise tonight, front brake hose brackets made, also managed to fit some bump stops(mot requirment?) not that the springs will ever hit them!!! then gave everything a coat of paint, starting to look like the elephant man due to an absus at  front off me mouth so not much else done as in a little pain!!!!!!!!!!!!! dentist first thing in morning.
tomorrow i should hopefully get brake lines connected and stick some fluid in an have a little bleed ing fun!!!
