December 19, 2025, 05:57:25 PM *
Author Topic: Suspension lift  (Read 8906 times)
« on: April 05, 2011, 12:01:17 PM »
Can anyone explain how those little 'dog bone' shaped bits allow the rear suspension to be raised on streetfighter-y type bikes?
« Reply #1 on: April 05, 2011, 12:22:04 PM »
Using different length dogbones in effect lengthens the shock,
by rotating the knuckle that the shock is attached to,
the shorter dogbone will raise the back -end.
« Reply #2 on: April 05, 2011, 07:30:36 PM »
Nope, sorry buddy, still don't get it!!!
« Reply #3 on: April 05, 2011, 08:28:05 PM »
Me neither!  I'm so glad someone asked - but the answer just says what they do, not how they do it!  - or where?
« Reply #4 on: April 07, 2011, 07:13:13 PM »
By pivoting  Grin.
Check the pic, and which bit is bolted where on the triangular plate, then imagine what would happen if you altered the length of the dogbone.
A longer one will push the plate back and pull the shocker down, a shorter one will pull the plate forward and in turn raise the shocker.
bigdarren
« Reply #5 on: April 07, 2011, 08:23:11 PM »
i have just fitted a set to my bandit there 50mm shorter that the stadard ones giving a 50mm raise
if you cant fix it with gaffa tape or cable ties then its broken
« Reply #6 on: April 07, 2011, 09:29:45 PM »
Well done tbone,i had no pics to describe this,I don't have paintshop on this pc either so i could not draw it.
« Reply #7 on: April 08, 2011, 12:36:01 PM »
Aaaaaaaaaaaah! I get it! Smiley
« Reply #8 on: April 08, 2011, 07:03:38 PM »
You got a new bike Clive?
« Reply #9 on: April 08, 2011, 07:43:38 PM »
Yup, bought myself a little Bandit runabout for the good weather!!!!!! Grin
bigdarren
« Reply #10 on: April 08, 2011, 07:58:04 PM »
if ya gunna jack it up you will need some help, just done a 50mm lift on my bandit and had to get my mate to push the swing arm down with his foot till the holes lined up  Smiley
bigdarren
« Reply #11 on: April 08, 2011, 08:10:42 PM »
before
bigdarren
« Reply #12 on: April 08, 2011, 08:11:35 PM »
after
« Reply #13 on: April 08, 2011, 09:56:54 PM »
Now I understand why I didn't understand!  Of course I'm stuck in the days of the twin shock!
Daddy Bear
The older i get the faster i waz
« Reply #14 on: April 09, 2011, 08:10:12 AM »
 Grin do they do them in red to
