March 21, 2026, 10:31:17 PM
Trike Tech
One for Mr M.
Topic: One for Mr M. (Read 1959 times)
One for Mr M.
July 28, 2010, 05:12:33 PM »
A question for MR M,or anyone that may have used this method of gearchange,
Without having to make the stick to long and having lots of sloppiness,
Do you think i have enough clearance or are the seat rails to far appart,see pic.
One for Mr M.
Also the height of rails see pic.
One for Mr M.
Re: One for Mr M.
July 28, 2010, 05:55:19 PM »
Erm, don't quite understand the question-
you want to bring the gearchange up through the seat, so it's in your lap, as my last trike was? That's the ideal position for keeping gearchange sloppiness to a minimum, but you may have to sit a little further back than you planned -don't forget you need to be able to change gear when wearing bulky waterproofs for example. I screwed a short extension onto the original gearstick to bring it up above the seat padding. However, by extending the stick, I increased it's travel between gears -obviously you don't want it hitting a frame tube before it's engaged the gear. Again, don't forget you need to try that with heavy gloves on as you might find your gloved fist hits the back of the tank when you change into first & third for example.
Can't really advise much, other than to try it in all the gears & see if it fouls anywhere. My own current trike build features a gearstick with a couple of bends in it that exits sideways, just under my left leg. Very comfortable to use, but also very sloppy with lots of travel between the gears, so I might rethink it before it's finished.
Re: One for Mr M.
July 28, 2010, 08:40:33 PM »
Andy Sorry if the question is a bit vague,but looking at your latest build that is the sort of thing i'm talking about.
