March 04, 2026, 08:02:31 PM *
Pages: 1 ... 118 119 [120] 121 122 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 697279 times)
flc
« Reply #1785 on: January 28, 2017, 12:09:36 AM »
http://i199.photobucket.com/albums/aa219/FLC_photo/Mobile%20Uploads/2017-01/9209A8B6-3926-4018-9EAB-A8AB258666AC_zpssvvnaq9c.jpg
It's all steps in the right direction mate
« Reply #1786 on: January 28, 2017, 08:36:33 AM »
The hospital wouldn't let me home till I'd walked up some steps (14) first.. Grin
« Reply #1787 on: January 28, 2017, 02:00:39 PM »
 Smiley New "Belleville" locking washer arrived in the Post this morning, so I'm ready to have another crack at it, but relying on BayChimp for enthusiasm at the moment!
flc
« Reply #1788 on: January 28, 2017, 03:36:28 PM »
But imagine when it's working correctly, it'll be right good Grin Cool
« Reply #1789 on: January 28, 2017, 07:27:25 PM »
Yeah. Eventually it'll run out of problems. I just have to outlast them, that's all  Smiley
Stix
« Reply #1790 on: January 29, 2017, 01:43:48 PM »
https://www.facebook.com/groups/753718781386134/
Scroll down a few posts and there is an almost motor for £75.00
Spares??
« Last Edit: January 29, 2017, 01:45:39 PM by Stix » Logged
« Reply #1791 on: January 29, 2017, 06:44:20 PM »
Looks like a closed membership group mate.
« Reply #1792 on: January 29, 2017, 07:25:04 PM »
it is a closed group  but a mate of mine is a member so i,v requested to join   Wink Wink Wink
Stix
« Reply #1793 on: January 29, 2017, 07:48:51 PM »
https://www.facebook.com/dave.bikes.1?lst=1108749117%3A100013454584516%3A1485719217
This is his face book page maybe contact direct. The motor post doesn't show up so you might need to message him.
Stix
Bugger looks like collection only from Northern Ireland.
« Last Edit: January 29, 2017, 07:53:37 PM by Stix » Logged
« Reply #1794 on: January 29, 2017, 07:59:58 PM »
 Cheesy Just as well I don't really need a spare then!
Stix
« Reply #1795 on: January 30, 2017, 10:03:38 AM »
Yup but thought the clutch and associated parts might be useful and them sell off the rest of it.
Stix
« Reply #1796 on: January 30, 2017, 01:36:44 PM »
True.
« Reply #1797 on: February 01, 2017, 08:16:45 PM »
Perforated stainless tube for the exhaust baffles finally arrived today -the 2nd lot after the 1st apparently went astray in the Post -bloody Posties  Tongue
This was the smallest diameter I could find on Ebay & is 32mm ish. The pipes are 41mm ish, so there won't be much room for wadding, but I'm hoping I can get one wrap around it, (need to buy the wadding now). I don't want to choke the engine by reducing the diameter too much, so will see how this works out. I bought 4 lengths so could extend them by another 100mm or so to completely fill the exhaust & might try that first, so I can shorten them to suit if needed.
I'd previously bought some stainless stepped pipe reducers to use as collars at each end. The large end's actually exactly the same O/D as the pipes though, so they'll need slitting & pinching in a little until they slide inside. They'll be held with a 6mm captive nut welded into the back end.
At the moment I've got 300mm long conical perforated tube baffles, so whether these 500mm long straight ones with some light wadding will be any better I've no idea. We'll find out.
« Reply #1798 on: February 01, 2017, 08:17:28 PM »
« Reply #1799 on: February 03, 2017, 06:51:32 PM »
Back to the bike again today, with my trusty sidekick, BayChimp, for added enthusiasm.  Smiley
I was tinkering with the exhaust baffles when he arrived at the garage, so I left him to remove the engine casing & fit the replacement clutch centre, (from an early model XS). As we had 2 sets of clutch plates, we decided to go with the older option of 7 friction & 6 steel, so used the newer ones, plus one of each taken from the Ebay clutch & put into the middle of the pack. We backed off the adjusting screw on the pushrod & slackened the cable, then re-set it all.
Result- we appear to have a working clutch, though we're being cautious about celebrating until the engine's running again & we can properly check it. Think it still needs some cable adjustment, but with the back wheel off the ground & in 3rd gear, the wheel spins with the clutch in & turns the engine over with the clutch out -so seems to be doing what it should. Hurrah -maybe.
The lever still feels a little stiff, but it's a long time since I've ridden an XS & I can't remember how they felt. It may ease off with some use or adjustment. Absolutely no reason why the other clutch didn't work, but it just didn't.
« Last Edit: February 03, 2017, 06:53:52 PM by Manky Monkey » Logged
