March 05, 2026, 05:33:41 AM *
Pages: 1 ... 105 106 [107] 108 109 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 697588 times)
« Reply #1590 on: December 08, 2016, 05:05:32 PM »
MOT hopefully won't be a problem.
« Reply #1591 on: December 08, 2016, 05:15:47 PM »
A phone call to Swansea (and a genuinely helpful person) did some delving and revealed the ref number on the V5C wasn't, for an undisclosed reason, being recognised by the system.
Sounds like another gov. cockup!  Probably forgot to pay for hosting of the MOT site!
Dslam
« Reply #1592 on: December 08, 2016, 05:45:58 PM »
maybe a limp and an eye patch then Wink
Dslam
« Reply #1593 on: December 10, 2016, 06:40:00 PM »
Bar the MOT tis done. Indicators working. Legal (probably temporary) number plate fitted.
Runs really well. My next day off is Thursday. Will try to get it booked in for then.
« Reply #1594 on: December 10, 2016, 06:56:32 PM »
The chief monkey will be pleased
« Reply #1595 on: December 10, 2016, 07:30:17 PM »
Yes he will. You Sir, are a little twinkly star. Appreciate all your efforts.
Mr 'Slam has the specialist knowledge to sort the carbs out & fix a few other odds & ends, but I also wanted a 2nd opinion on my own spannering. I haven't built a bike for a few years & wanted someone to check it over with a fresh eye. Hopefully I haven't done anything too stupid then.
Thursday's my day off too Andy.
« Reply #1596 on: December 12, 2016, 10:00:29 AM »
Romance is in the air ? Roll Eyes
« Reply #1597 on: December 12, 2016, 05:49:48 PM »
 Kiss
« Reply #1598 on: December 12, 2016, 06:35:46 PM »
Mr monkey and dslam with all your lovely messages to each other  Wink
« Reply #1599 on: December 12, 2016, 07:46:37 PM »
He's a jolly nice fellow.
Dslam
« Reply #1600 on: December 19, 2016, 06:54:21 PM »
Hi Boss,
Had a few issues. Not all with the bike!!
Can you give me a call mate. The PM thingy doesn't seem to be working and my mobile got changed out and all my contacts went walkies. POOO!
« Reply #1601 on: December 19, 2016, 09:07:02 PM »
Hmm. Well, just got off the phone to Mr 'Slam.
A sudden family bereavement means he just can't commit to any more time on my -or anyone else's -bike & has led to him re-evaluating things in the past few days. Life's too short & there are far more important things than bikes -my sentiments, maybe not his.
So the XS will be heading back soon, with the carbs sorted & engine running nicely, but a rather daunting To Do list. Not quite back to the drawing board, but definitely back a few pages.
Andy's going to jot down a list, but it's basically:
Clutch still dragging, despite me having replaced every single component in it, from the lever, to the cable, to the worm drive to the pushrod to the plates. Not quite sure where to go with that one.
Battery not charging. It's had 2 new batteries now. Could be the alternator, could be the rectifier, could be the actual wiring loom. I suspect it'll be getting re-wired. Again.
Needs more fuses. It's got 4. Andy would prefer to see 6. I'd already decided to swap the old glass style fuse box for a newer blade fuse type anyway, as I've had problems with British bikes in the past, vibrating the fuses apart. So now would be the time to do that & maybe mount it on the inside of the left side panel for ease of access.
I've also already decided the rear brake master cylinder needs changing -my brother Steve made up a beautifully engineered cross shaft across the frame from the pedal to the master cylinder on the other side, but the return spring bracket hangs low under the bike & makes it a real pain to roll up a ramp into a van, which is how it seems to be travelling a lot at the moment. I'll swap the whole set-up for a more common Harley type cylinder mounted directly off the pedal. Much simpler.
The rear brake torque arm needs some modification. Not a lot, but the current set-up means that under really heavy braking it'd be possible for the caliper to move over-centre & swing around the disc. A second locating tab on the frame should fix that.
The indicators really do need replacing with something sturdier & the rear ones need moving away from the exhausts. As It's a 1980 bike, I could just bin them, but I'd like to live a little longer yet & modern drivers have probably never seen a hand signal. I plan to SVA the bike at some point too, so flashers will be needed then.
My second set of very expensive stainless exhausts are just way too loud for regular use. Again, really not sure what to do with them. Splicing a stainless dual entry/exit silencer into the middle seems to be the only real option, but I've no idea how much difference it'll make.
I think that's about it. Certainly enough to be going on with.
Really sorry to hear your news Andy. Thanks for all your help mate.  Wink
« Reply #1602 on: December 19, 2016, 11:25:04 PM »
Well, that's a shame that your buddy has probs. but of course, family considerations are paramount. As for 'the list', don't be too hasty, as the clutch may be no more than putting miles on it to remove any " fluffy-ness", assuming of course its lifting squarely, and has a full compliment of shims and/or any spacers, in the correct locations. The generator is easily checked by anyone who understands auto-electrics, and would confirm, or otherwise, the state of play. Sounds like the rear calliper does indeed need to be fixed in the positive manner, not as a "floater", and the master cylinder fix you have covered. Put a pair of cheap and cheerful after market indicators on until you have more time to fix/consider the preferred final result! As for silencing, maybe a bypass baffle insert would suffice, removing baffles in turn until the acceptable noise level is achieved, not so much really.....if you say it quickly!! Grin Grin Grin..Morrag
« Reply #1603 on: December 19, 2016, 11:48:54 PM »
Do you need indicators/baffles when pushing it about boss ?...I will get my coat !
« Reply #1604 on: December 20, 2016, 05:29:25 PM »
 Tongue
Andy's returning the bike on Christmas Eve, so I'll take a good look at it over the Christmas break. It's a shame to re-do stuff now it's all nicely coated & painted, but if it has to be, it has to be. I fully intend to keep this bike forever & never build another, so it's worth taking the time to get it right.
The clutch plates barely seem to separate, despite having all the right components in place. I put them in dry though, so it might just be a matter of taking them out & soaking them in a tub of oil for a week then replacing them.
I remember Nathan was baffled by the alternator/rectifier arrangement for a while -he's a car guy & had never wired a bike before -so it may just be wired up incorrectly. I don't understand electrics at all, but have a Haynes manual, so hopefully someone more competent can check the wires are actually going where they should.
Explain your bypass baffle to me Mr M.
