April 16, 2026, 07:14:42 PM *
Author Topic: Glow plug failure diagnostics...  (Read 3372 times)
o0Mouse0o
« on: April 15, 2010, 06:59:41 PM »
Had another failure - getting valve and valve seat sorted locally but the glowplug also failed and I'm after some advice.
This is the condition of the glowplug in the side that just overheated and failed (again).  Its an air cooled 1974 German V twin diesel engine.
During the last hour of operation I can say there was a leaky valve (bent) so low compression and it was maybe sucking in a bit of sump oil through an oil leak in the rocker cover that was dripping onto the air filter.
Does it show classic signs of something being set up wrong.
http://www.aarrgghh.co.uk/ratbikes/DieselBike/Glow01s.jpg
http://www.aarrgghh.co.uk/ratbikes/DieselBike/Glow02s.jpg
http://www.aarrgghh.co.uk/ratbikes/DieselBike/Glow03s.jpg
A replacement is slim as its a 0.9Volt 40Amp beastie thats not fitted to anything I can find ad there was only one cross reference part I found but it was 10 mm to long. I can see me finding a modern slim glow plug the right length and hollowing out and threading the body of this one to take it
« Reply #1 on: April 15, 2010, 08:55:11 PM »
While my eastern european aint great....
Can you let me have the bosch number from the plug you have.
I think the NGK no. is Y-811
« Last Edit: April 15, 2010, 09:16:25 PM by tbone » Logged
o0Mouse0o
« Reply #2 on: April 16, 2010, 09:08:52 AM »
WOW!! Where did you find that! I'd like to see the other pages of that book to see if it is the same (or similar) engine.
Looks very similar. The bosh number of my bit is 0250 001 010 and 0.9 Volts!
The dropper resistor is also identical, and the regulator can also looks the same. And there are two plugs suggesting a twin engine  Wink
I've also spoken to a few diesel mad friends who say the oil that was leaking into the inlet manifold will almost certainly be enough to cause over-fuelling and give overheating and this sort of damage to the glow plug amongst other problems
A readily available equivalent would be ideal but I'm thinking of knocking out the centre of the two I've got (Or finding a M18 x 1.50 bolt) and tapping it to take a modern 12V glow-plug.
« Reply #3 on: April 16, 2010, 01:40:02 PM »
Its the same engine  Wink
I`ve got 3 editions of the manual, the first two are up to 1965 & then 1968 and cover the single and twin cylinder versions, the third version also includes the four cylinder model, they are unfortunatly in czech though, If you PM me your address, i`ll get a disc in the post to you.
o0Mouse0o
« Reply #4 on: April 16, 2010, 02:12:30 PM »
That's fantastic!!
I'll hold off sending contact info as I'm going to be away for 10 days and don't want to play the missed delivery game.  Wink
The tappet clearance would be good to know.
Your profile says you are in Gloucestershire,
As a return favour I can test drive it in your general direction if you want to see it in the flesh!
« Reply #5 on: April 16, 2010, 04:23:19 PM »
Then the two of you can take some photos for a write-up for the site.  Grin
« Reply #6 on: April 16, 2010, 05:25:35 PM »
No probs, just let me know when your back, in the meantime i can email the workshop manual to you. Its a 23mb file so i`d need to split it, but thats not a problem.
Clearances look to be 0.15mm cold
forget the ngk part number i posted before....its wrong....
However....
 Durite       0-131-04
 Champion  CH28 (AG28)
 Lucas       HDS319 (DS104)
 Beru         214GK
 Durite       0-131-04
 NGK          DG237
 Wellman    W101
are all correct...........just for info  Wink
« Last Edit: April 16, 2010, 06:26:58 PM by tbone » Logged
« Reply #7 on: April 16, 2010, 09:10:38 PM »
tbone are your last names National Library? Wink
