March 23, 2026, 02:47:16 PM *
Author Topic: More help please reliant gearbox  (Read 4064 times)
gtchippy
« on: April 12, 2010, 02:28:44 PM »
I Have 2 gearboxes,& want to swap the back plate which holds the mounting bracket,question is does the back plate just come off or is it connected to all the gearing etc.
Hope that makes sense.Cheers George.
« Reply #1 on: April 13, 2010, 08:06:37 PM »
Hi George,
the rear cover holds the back end of the gearbox main shaft. If I remember right, you can slide it off, but it's easy to disturb the synchro mesh sleeves inside, so be very careful. If you're only changing the cover because one of the mounts is damaged, it's probably easier to just redrill it & tap it out to a larger thread size, without dismantling the box.
gtchippy
« Reply #2 on: April 14, 2010, 05:10:28 PM »
Hi,thanks,as you say sounds risky,so will leave well alone,& rethink how i fit gearbox to chassis,as the 2 gearboxes have different fitments,hence my original question.Cheers.
« Reply #3 on: April 14, 2010, 05:31:47 PM »
Our engines are solid mounted, rather than on the Reliant rubbers, so I just used bolts of the same thread. Makes it easier to re-tap the mount on the gearbox to a different thread if necessary.
« Reply #4 on: April 14, 2010, 07:34:08 PM »
Different how?  Huh
gtchippy
« Reply #5 on: April 14, 2010, 07:47:47 PM »
One gearbox has a large rubber bush which bolts to the bracket,the second one has no bush just 2 tapped holes.
Maybe one is quite an old gearbox Huh?
« Reply #6 on: April 14, 2010, 07:54:40 PM »
Not sure about the bushed one. The most common is the 2 tapped hole type, which take 2 seperate rubber "bobbins".
gtchippy
« Reply #7 on: April 14, 2010, 08:16:13 PM »
The one with the rubber bush is all one peace on the backplate,where as the other has no bush on the back plate,now i know about the bobbins,i will drill & retap get bobbins to fit then see about making some sort of bracket to fix to.Thanks for your help.
Free Fish&chips if your ever down this way.
toad
« Reply #8 on: April 14, 2010, 08:23:36 PM »
that,ll be an early regal box Wink
steven brock
« Reply #9 on: December 14, 2010, 10:49:29 AM »
ok i have no gear selection on the reliant box! Huh, i did take the rear cover off to fit a new gasket as had a slight leak (with a bit of effort), could i have damaged something, seemed to go back together ok!!...ummmm
« Reply #10 on: December 14, 2010, 11:00:17 AM »
did you refit the three selector shaft balls and springs
or the selector shaft pins
steven brock
« Reply #11 on: December 14, 2010, 11:30:33 AM »
hi ok i have two springs and two balls under those springs on the top plate (were the gearlever go's) i can seem to select the gears but the shaft either locks or rotates the same speed as i rotate the rear driveshaft flange... getting a bit confused! thanks for ya help
i did take the rear cover off (the one with the gearbox mounts) and replaced the seal and gasket...ummm Huh
