November 07, 2025, 06:10:39 PM
Trike Tech
reliant axle wheel bearings
Topic: reliant axle wheel bearings (Read 3172 times)
brains
January 24, 2010, 09:49:57 PM »
did someone recently post the number of the bearings and a cheap supplier or was I dreaming ?
Re: reliant axle wheel bearings
January 26, 2010, 01:45:40 PM »
I am sure someone has posted about cheap bearings last week but darned if I can find where. Wonder if the search will find it, will have a go
I must have dreamt it or else it was something other than bearings cos Search isn't finding it sorry
Last Edit: January 26, 2010, 01:48:12 PM by nabsim
BTW-UK forum
BTW-Area51
January 26, 2010, 07:17:35 PM »
The half-shaft bearings are 6305-L8: 62x25x17mm, and the accompanying seals, Gaco IND.49516. The pinion bearing is an L44649, and the pinion oil seal is Gaco. IND. 49517. I get mine from E.B.R. Bearing Supplies of Bolton. They advertise on "E" Bay, or they have a Web Site,
www.ebrbearings.co.uk
. I have found them excellent on price for all my bearing requirements, so ask them for a quote, ....Morrag
brains
January 26, 2010, 09:09:18 PM »
cheers for the info and will email them pronto for a quote thanks
January 27, 2010, 05:19:00 PM »
Have just bought 2 halfshaft seals & bearings from Michaels, £42.66 inc delivery. They asked me for measurements as there are more than one size bearings/seals used.
brains
January 27, 2010, 06:20:49 PM »
best I measure the old ones then , thanks for the advice
Reply #6 on:
January 27, 2010, 08:43:28 PM »
Always best to check dims, but the last three axles I have overhauled all had metric half shaft bearings, 6305 2RS's, that's a double shielded 6305 ballrace, and I paid £4.83 a pair for the last ones I bought, inc. postage from E.B.R. Bearings, so there you go.... Morrag
Reply #7 on:
January 28, 2010, 09:54:46 AM »
I've been caught out once or twice -built axles using parts from different donors -casings from one car & drive shafts from another -& found the bearings didn't fit. I think Reliant used both Metric & Imperial fittings, so you need to measure accurately when ordering.
