April 16, 2026, 08:10:44 AM *
Author Topic: Digital speedo  (Read 7897 times)
« on: January 13, 2010, 07:54:06 PM »
Can anyone explain, in simple terms, how one of the after-market ones of these work? And if they're any good?
« Reply #1 on: January 13, 2010, 08:09:16 PM »
There's a magnet on the front wheel and a pick up on the forks which sends a pulse to the speedo which inturn calculates the speed, you have to programme the circumference of the front wheel in it's quite simple.
I recommend the Sigma ones maybe a bit dearer but will last longer than the cheap bicycle ones.
I have used a Sigma from Hein Gerike for the last 2 years only had one speeding fine so must work ok
« Reply #2 on: January 13, 2010, 09:03:52 PM »
Cheers buddy,
How does the magnet attach to the wheel, and surely if you put the circumference of the wheel in, it'll not matter how big the wheel is, but where along the radius of the 'circle' the magnet is fitted? Or am I being a biff here?
« Reply #3 on: January 16, 2010, 12:37:50 PM »
I used Araldite resin an put it on the rim but it don't matter where you put it it's just a counter provided you programme the unit with your wheels circumference accurately all will be well.
A bit of inventing to mount the sensor but it's nothing you cant handle.
« Reply #4 on: January 16, 2010, 12:44:09 PM »
You can buy "cordless" ones too, though their range is only a couple of feet -I tried one on a chop & the distance from front wheel to yoke mounted speedo was too far!
bitzman5
« Reply #5 on: January 17, 2010, 11:47:59 PM »
HI I HAD A CHEAP ONE OUT OF HAFORDS FITTED TO MY KITCAR PASSED SVA NO PROB SAME BATTERY 2 YEARS ON
« Reply #6 on: January 18, 2010, 08:13:42 AM »
Also the coils can interfere with the signal.
« Reply #7 on: January 18, 2010, 06:13:43 PM »
Does SVA require the speedo to be illuminated?
gazzagood
« Reply #8 on: January 18, 2010, 06:49:34 PM »
not got a book but sure i read it some where that must be illuminated.but almost sure they have to be
PLEASE
« Reply #9 on: January 18, 2010, 07:23:00 PM »
I think so but never had mine checked
bitzman5
« Reply #10 on: January 19, 2010, 01:36:48 AM »
Yes thy do mine was light up by a mounted micra number plate light
« Reply #11 on: January 19, 2010, 12:17:35 PM »
I got a vapor one for xmas.It is backlit.The pick up magnet is a special replacement bolt for the  brake disc to hub. You then calibrate it as per the instructions.It has a rev counter ,trip meter ,etc etc all built in .
« Reply #12 on: January 19, 2010, 08:07:01 PM »
I wanted one of them but a bit too much out of my pocket money!
phill cbx
« Reply #13 on: February 08, 2010, 06:33:49 PM »
yes i recomend the trailtek vapour does all you want and more,
easy to use and view , tried and tested,
regards Phill
« Reply #14 on: February 10, 2010, 09:42:08 AM »
These look pretty good.
http://acewell.co.uk/
