December 23, 2025, 08:20:27 AM *
Author Topic: reliant axle pinion oil seal  (Read 2691 times)
master_of_wishes
« on: January 11, 2010, 10:37:01 PM »
whats the oil seal like to do on the prop side of the diff...had to remove the prop today and the small space between the pinion flange and prop flange is full of diff oil,yet no leak under the diff
has anyone a blow up pic of the diff/pinion setup please...
master_of_wishes
« Reply #1 on: January 11, 2010, 10:42:48 PM »
forgot to add,i found the exploded reliant axle diagram in some previous posts but i cant blow it up clear enough to make out the individual parts ...
« Reply #2 on: January 11, 2010, 11:49:49 PM »
PM me your address mate & I'll send you a copy of the Haynes Reliant manual on disc.  Wink
« Reply #3 on: January 12, 2010, 12:15:00 PM »
Had mine done earlier this year and the mechanic said it was a 10 minute job! (maybe a slight exaggeration) - what took the time was having to deconstruct most of the back of my trike!
« Reply #4 on: January 12, 2010, 02:11:59 PM »
Remove the prop shaft, put the handbrake on so the rear wheels can't rotate & undo the big nut in the centre of the prop flange on the front of the axle diff casing. It might need a sharp crack with a mallet on the end of your socket bar to shock it loose -yeah, I know you shouldn't hit sockets. They don't call me Manky for nothing.  Smiley  There might be a tab washer behind the nut to stop it vibrating loose. If so, bend the tabs back, clear of the nut first. Tap the flange off, (it's on splines), & you'll see the oil seal behind it.
It's a very common leakage point on Reliants. Unfortunately, because the flange rotates, it only takes a small amount of oil to spray the stuff everywhere. With the flange out of the way you should be able to prise the old seal out. It might have a pressed tin casing around it, not sure. If not, it's just rubber. Try not to damage the aluminium diff housing when you hook the old seal out. If you do scrape it, smear a little gasket sealant around it before tapping the new seal back in. I usually use a large socket, placed open end over the seal, to knock it back in evenly. Then slide the flange back into the centre of the seal, lubricating it with a sear of grease. Refit the nut & bend the tab washer up to secure it if it has one.
Inside the diff casing is a crushable collar. When the flange is first tightened down to the correct torque settng, it should squish down to take out any play in the gears. I once replaced the collar when changing a seal but haven't bothered since & it didn't seem to make any difference.
Torque setting for the nut is 70 - 85lbs/ft.
master_of_wishes
« Reply #5 on: January 12, 2010, 09:31:42 PM »
cheers for that manky,cant figure out tho why its filled the void between the prop and diff flanges with oil yet has no oil leakage around the pinion shaft,gonna redo the brakes when i do the seal,there useless,hardy feel them pulling up at all
