February 19, 2026, 12:19:11 PM *
Author Topic: Tube Notcher  (Read 7636 times)
mrdeey
« on: November 03, 2009, 10:42:13 PM »
Got me one of those fancy tube notchers from the states , its a pro tools item running in 2" ball bearings adjustable for offset notching and variable angles , are they worth it ?, bit like the saying ,once u had black u never go back , or as i prefer once u had white u never as tight! you betcher! perfect fit every time ! just make sure you have a decent quality hole saw and dont drill too fast, n away you go .
« Reply #1 on: November 04, 2009, 12:01:21 AM »
Let's have a look at it then!
voodoo
« Reply #2 on: November 04, 2009, 02:23:04 AM »
Let us know if its anygood and how easy to use please.....Ive been thinking of buying one for a while now,if things go as planned I will be after one early next year...Voodoo....
Custom Paint Spraying...
mrdeey
« Reply #3 on: November 04, 2009, 09:51:04 AM »
http://i35.tinypic.com/2lj408h.jpg
Tube Notcher
http://i34.tinypic.com/2mrz8m0.jpg
Tube Notcher
looked at lots of em , before i got this one , the jd2 one is pretty good to , but i think this has the edge, as i said 2" ball bearings wiv a 1" steel shaft , it just sits in yer vice simple as that n nothing moves! quality stuff
« Reply #4 on: November 04, 2009, 03:56:37 PM »
um wots its powered via? pics look like its a good un Smiley
« Reply #5 on: November 04, 2009, 05:40:40 PM »
electric drill  Wink
« Reply #6 on: November 04, 2009, 09:22:37 PM »
can you give us a clue to the million doller question ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, the price of such a tool  Cheesy Cheesy
mrdeey
« Reply #7 on: November 04, 2009, 09:42:54 PM »
I can tease you no longer , picked it up for 19141.8448 yen plus post  Grin
« Reply #8 on: November 04, 2009, 09:46:47 PM »
bout £130 i reckon
« Reply #9 on: November 04, 2009, 09:47:31 PM »
 dosn,t any one use £,s anymore Huh?? Cheesy Cheesy Cheesy
« Reply #10 on: November 05, 2009, 05:19:40 AM »
Looks a cool tool that.Depends how much you are gonna do to make it viable tho'.
DIZZY
Ride it like you want it
« Reply #11 on: November 05, 2009, 08:30:59 AM »
Looks like a great tool does that!!...............just a thought,has any one tried using a hole cutter in a pillar drill? to do this job? its an idea i wanted to try but aint had a chance yet.
Looking at these pictures, if you took it out of the vice and put it up right youd av a pillar drill? i just wonder if doin it  with a pillar drill it might be prone to jamming.
Just a thought but a lovely tool !!
Dizzy
« Reply #12 on: November 05, 2009, 08:57:13 AM »
Think i remember trikerpete saying he uses a holesaw in a pillar drill  Huh
« Reply #13 on: November 05, 2009, 09:32:55 AM »
PD & Loony used a pillar drill when cutting frame tubes for PD's little brother's bike. I think it worked O.K
Personally I find it much quicker to grind them to shape with an angle grinder, but then, I always take the awkward option on any job.   Tongue
« Reply #14 on: November 05, 2009, 12:25:07 PM »
Another way to notch tube is to put a milling cutter in the chuck of a lathe,and clamp the tube to the tool holder. If you have a lathe of course! and also depends how big the tool holder is to clamp larger diams in . I like to grind them out myself.
