February 20, 2026, 12:03:31 AM *
Author Topic: bond bug axle  (Read 3590 times)
mrdeey
« on: September 28, 2009, 05:45:17 PM »
hi , i have just obtained a bond bug axle , got a couple of questions , what ratio is it , what pinion oil seal fits , unlike the robin realto axles it has 3 holes in the back plates and i am one short! also does anyone no what thread / size the hub nut is ?
« Reply #1 on: September 28, 2009, 09:43:48 PM »
Never ever had any dealings with Bond Bug parts I'm afraid Mr D. I'm sure someone here will have the info, but in the meantime, got any pics of it?
« Reply #2 on: September 28, 2009, 10:49:45 PM »
My understanding is that the Bug and Pig axles are the same, which is why you sometimes come across Robin axles with "3 hole fixing backplates", check the o/a length, back plate to backplate, the Robin is 46.25 inches.As for ratio, just lock one half shaft and count the turns, pinion to other halfshaft, Robin is 3.23:1, C.W=42T,& Pinion=13T, Morrag
mrdeey
« Reply #3 on: September 29, 2009, 09:57:46 AM »
Thanks dudes, the thing is the same as the 3 piece pig axle with the axle tubes bolted to the casing ,had a reply from the reliant site to , the ratio is 3.55: 1 in case anyone else finds one
mrdeey
« Reply #4 on: September 29, 2009, 05:33:26 PM »
bit more info , the backplates with the three holes are from rear drums of a mini and so are the brakes themselves, the two plugs on the diff are for oil level and for draining, there is a little brass breather on the top , which has the same function as the one on other reliant axles , also serves as a "this way up " clue , else oil is gonna piss out the bottom! will put a pic or 2 up if anyone is interested?
« Reply #5 on: September 29, 2009, 09:00:28 PM »
Yes please, info will always be of use to someone.
« Reply #6 on: September 30, 2009, 01:26:46 PM »
But if it's being used with a bike engine you may have to use it upside down (as with mine) so as not to have 6 reverse gears and one forward!
« Reply #7 on: September 30, 2009, 01:40:36 PM »
That would of course depend on the direction of rotation of the particular 'bike engine to be used, Morrag
