									 « Reply #120 on: March 27, 2011, 03:37:49 PM »  |
							You lost me after the first line, but very impressive Tim!
									 « Reply #121 on: March 27, 2011, 04:26:04 PM »  |
							Ok, lets start again.
  Goldwing 1000 correct? has a primary reduction of 1.708       a secondary reduction of 0.825 giving 1.4091 overall reduction of crank to the input shaft. 1st gear = 2.5 2nd gear = 1.708 3rd gear = 1.333 4th gear = 1.097 5th gear = 0.939 Final drive = 3.40
  Lets stick to your 4000 rpm Eng = 4000 divided by overall reduction 1.4091 = 2838 rpm at the input shaft. Output = 2838 divided by final drive ratio 2.78 = 1020 rpm at the wheel.
  To convert to MPH = engine rpm x raduis divided by final drive ratio x 168
  4000 (rpm) x 4.43inches (tyre height) plus 7.5inches (half wheel diam) = 4000 x 11.93     = 47720 1.78 (primary reduction) x 0.825 (secondary) x 0.939 (5th gear) x 2.78 (final drive) = 3.83 x 168 = 643 So  477720 divided by 643 should give you 74mph in 5th gear at 4000 rpm using your current diff/wheel setup.
  you done this just for me.Thanks tbone   now what would it be if i had a 3.55 diff and 205 60 15 wheels     only joking thanks again
									 « Reply #122 on: March 27, 2011, 05:06:41 PM »  |
							no problem. You just need to remember the reduction from camshaft to crankshaft
							trev
									 « Reply #123 on: March 27, 2011, 07:34:29 PM »  |
							wow my brain has melted.
									 « Reply #124 on: March 27, 2011, 08:31:56 PM »  |
							Ok, lets start again. Goldwing 1000 correct? has a primary reduction of 1.708       a secondary reduction of 0.825 giving 1.4091 overall reduction of crank to the input shaft. 1st gear = 2.5 2nd gear = 1.708 3rd gear = 1.333 4th gear = 1.097 5th gear = 0.939 Final drive = 3.40 Lets stick to your 4000 rpm Eng = 4000 divided by overall reduction 1.4091 = 2838 rpm at the input shaft. Output = 2838 divided by final drive ratio 2.78 = 1020 rpm at the wheel. To convert to MPH = engine rpm x raduis divided by final drive ratio x 168 4000 (rpm) x 4.43inches (tyre height) plus 7.5inches (half wheel diam) = 4000 x 11.93     = 47720 1.78 (primary reduction) x 0.825 (secondary) x 0.939 (5th gear) x 2.78 (final drive) = 3.83 x 168 = 643 So  477720 divided by 643 should give you 74mph in 5th gear at 4000 rpm using your current diff/wheel setup. I`ve got a headache !!!!!!!!!!!!!!!!!!!!         So 74mph in 5 gear @4000rpm i will put that to the test when ive set the carbs up
									 « Reply #125 on: May 02, 2011, 10:18:39 PM »  |
							Update.been riding trike trike around the town.and for a while i have notice that the water in the rad has to be topped up after a long run.so i thought i will check it out.done a cylinder leak test and found that it was pressurizing the rad on cylinders 2/4. so it was heads of to have a look and this is what i found cylinder 2/4  i was told this had an engine decoke just before i got it and i have not done many miles on it               cylinders 1/3         cleaned it all up and put it back together giving a 30 mile run and seams ok    i am hoping it will be ok for a run to basingstoke on sunday
									 « Reply #126 on: May 02, 2011, 10:23:47 PM »  |
							Looking forward to seeing you there on it Terry.
									 « Reply #127 on: May 03, 2011, 09:03:19 AM »  |
									 « Reply #128 on: May 03, 2011, 09:26:44 AM »  |
							say no more what ever turns you on    are you  coming ops. going to basingstoke
							Hagar
									 « Reply #129 on: May 03, 2011, 04:10:32 PM »  |
							Whats your tongue like on rust  ? ......    ..  Hagar  ..
									 « Reply #130 on: May 03, 2011, 05:44:54 PM »  |
							Why? Why?.............I know I`m doing it but I just keep on typing and my brain overtakes my fingers.........................it`s a sort of tactile  diarroah  diarheah diarrhoea runny bum I suppose.............doubt I`ll ever learn.............but if it makes you lot smile then that`s fine by me.............if it doesn`t then B****x to you
 Sadly I can`t make Basingstoke now, it sort of crept up on me and I`ve got a lot of organizing to do for The East Anglia D-Day Memorial Ride on the 4th of June. Besides that not feeling too good this week. worked on Cuddles trike all day  Saturday and I`m paying the price now with a very stiff neck and can hardly walk. Hey ho life goes on.
									« Last Edit: May 03, 2011, 05:51:57 PM by Cabman77 »
									 « Reply #131 on: May 05, 2011, 09:08:27 PM »  |
							went for another run on the trike today. no were in pertickler. just a ride to make sure that every thing was OK after doing the heads.well after a ride around the back roads.and sat/nav getting lost no gps. i ended up at hindhead on the A3. well that's about 30 miles from my place one road with only one round about on it. well        70/75 all the way apart from slowing down at the roundabout till i got home.i am very happy with the way it handles no shakes wobbles at any speed just a very enjoyable ride.did about 52 miles in all.got home let it cool down checked water level Al's fine might go for a cruise tomorrow keep speed down to 50 just to see some of the country side. then basingstoke on sunday
									« Last Edit: May 05, 2011, 09:20:36 PM by terry t »
									 « Reply #132 on: May 05, 2011, 10:17:21 PM »  |
							A happy triker then. Lucky git.
									 « Reply #133 on: May 10, 2011, 09:06:09 PM »  |
							Trikes sick only running on three cylinders use nearly 8 litres fuel on a 10 mile run. i will get more if i put a V8 in it    no. so cant ride it   so i will be in the van   with the trike behind me   going to basingstoke Took the carbs of again (ground hog day) to see whats happening. i pinned it down to the carbs on the near side.drained the fuel out of the bowls.took the bowls of all seamed ok.then when i checked the floats no 4 was stiff so wasn't closing properly.on investigation i found the pin that holds it in place was bent.how it bent i dont know.so to the spares box new pin fitted and checked for level and movement.put all back together.then tested by pumping fuel in to check for leaks and that the valves are closing        will put them back on trike tomorrow be glad when i have sorted this single carb conversion    better change the oil as well probably a bit thin now
									« Last Edit: May 10, 2011, 09:10:09 PM by terry t »
									 « Reply #134 on: May 10, 2011, 09:09:07 PM »  |
							Well spotted Tel.
