November 10, 2025, 11:19:20 PM *
Author Topic: Electrical Problem  (Read 2586 times)
willy
« on: May 15, 2009, 04:56:43 PM »
A mate of as got a 1981 GS850 but..
Ignition dead...battery fine, lights etc fine but turn key & nowt happens
Any ideas
Cheers
« Reply #1 on: May 15, 2009, 05:13:17 PM »
First thing i`d do would be to check the voltage at the switch. If you cant do that then look for a fuse on the ignition circuit, or a loose connection at the switch. You should have 2 wires coming off the plus side of the battery terminal, 1 goes to to the soleniod, the other to the fuse box, that fuse then feeds the ignition switch.
 Wink
« Last Edit: May 15, 2009, 05:17:44 PM by tbone » Logged
willy
« Reply #2 on: May 16, 2009, 01:38:15 PM »
cheers t bone
