October 15, 2025, 10:48:44 PM
Bike Tech
Disc brake rotor.
Topic: Disc brake rotor. (Read 2453 times)
Disc brake rotor.
May 05, 2009, 05:31:11 PM »
Are 'bike brake discs made of any special type of steel? Is it ok to use a disc made from stainless,say 6mm thick?
Thanks
(for a parking brake ,not the main brakes)
Re: Disc brake rotor.
May 05, 2009, 06:07:15 PM »
Purely for a handbrake, to be applied when the vehicle has stopped, then i would say yes, you will get away with it.
Brake discs however are made from a variety of materials including cast iron and hardened steel with a high carbon content, to combat the heat generated from friction.
A mild steel compound would not withstand the heat or forces being applied to it.
Last Edit: May 05, 2009, 06:08:54 PM by tbone
May 05, 2009, 08:48:21 PM »
OK thanx, I 'll use a 'bike one.The reason I asked was that all the bike ones seem to have existing holes of various sizes in the centre area,therefore difficult to find a concentric mounting place when bolting it to the diff flange.
