November 11, 2025, 05:21:43 PM *
Author Topic: Wheels to fit 4x4"......  (Read 7163 times)
« on: May 01, 2009, 12:11:42 PM »
Looking for some rear wheels.....
 Will 4x100 fit to the 4x4"?
 Some of the wheels I like havent got enuf 'meat' on the hub area to re-drill holes between the existing ones.
 Make up adaptors?
      Rod
« Reply #1 on: May 01, 2009, 01:36:35 PM »
Simple answer, NO, 4x100mm aint the same as 4x4" PCD! Morrag,( if using steel wheels the 4x100mm PCD types, can sometimes be "persuaded" to fit 4x4" pcd, but its not best eng. practice, to say the least!)
peanut
« Reply #2 on: May 01, 2009, 03:06:47 PM »
http://cgi.ebay.co.uk/Dynamics-classic-mini-alloy-wheels-5-5jx13_W0QQitemZ300311527027QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item300311527027&_trksid=p3286.c0.m14&_trkparms=72%3A1689%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
Here's some 13" classic mini alloys that would fit
XJ750(UK)
« Reply #3 on: May 01, 2009, 03:24:09 PM »
there was a guy on ebay selling adapters already made up 4" to 100mm. I'll see if i can find him.
http://cgi.ebay.co.uk/Reliant-Mini-trike-axle-spacers-101-6-to-100mm-PCD_W0QQitemZ180344455050QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item180344455050&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A13%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
that set sold, but if you read the listing, he says he has more of them, may be worth emailing him?
« Last Edit: May 01, 2009, 03:36:59 PM by XJ750(UK) » Logged
« Reply #4 on: May 01, 2009, 05:52:00 PM »
Morrag ,thanx .
 Peanut,alot of those about but I need something like 15's with lowish profile tyres ,thanx anyway.
 xj750 ...Ive e mailed the spacer guy! Thanx
« Reply #5 on: May 01, 2009, 07:49:50 PM »
if you get stuck and need one, i`ve got a 1:1 scale drawing of the adaptor plate.
« Reply #6 on: May 01, 2009, 08:01:04 PM »
I reckon I might be able to make the adaptors myself ,but I'm a bit worried about getting them dead accurate .
« Reply #7 on: May 01, 2009, 08:14:05 PM »
As Mr M has said before, the difference in the pcd is only 1.06mm, thats 0.53mm per hole........basically bugger all. While i dont generally disagree with morrag, i personally dont feel its worth the effort and i happily run 100mm pcd wheels on my reliant axle.
« Reply #8 on: May 01, 2009, 08:19:34 PM »
'tis true ,its only 1/2 mm. I s'pose it depends on whether the nuts are the type that recess into the wheel ,or sit on the surface of the wheel.The recess type would be harder to get on . In any case,if the nuts werent tightened equally ,the wheel would be pulled to one side?
« Reply #9 on: May 01, 2009, 08:29:34 PM »
and dont forget your happy to fit discs with 100mm pcd  Wink.
Ultimately the decision has to be yours, but listen to all sides before making your choice.
« Reply #10 on: May 01, 2009, 08:36:05 PM »
so the Nova discs fit the 4"pcd ok?
« Reply #11 on: May 01, 2009, 08:45:00 PM »
The wheel studs on the nova are a larger diameter than the reliant, so natuarally the holes in both disc & wheel will be larger too. This tiny size difference allows them to go over the studs, if, like Mr M has done, you replace the original studs with 12mm ones, you`ll need to drill the hubs anyway, unless you are a precision engineer, the chances are you`ll `loose` that 0.53mm when driling.
« Reply #12 on: May 01, 2009, 10:53:46 PM »
Mr T when I machine the Reliant hub carrier to accept the Nova discs, I ensure that the disc sits on the new "register" that I machine, and therefore the slight PCD diff. does not become an issue.Morrag
« Reply #13 on: May 01, 2009, 10:56:26 PM »
Morrag's quite right to point out it's not perfect engineering theory, but in practice it works fine. Over enthusiastic wheel nut tightening will probably stretch the studs more than half a mill anyway. He's also right about machining the centre boss down to fit the discs so that they centre on the shoulder.
Personally I'm quite happy to run 100mm wheels on 4" studs, but you're responsible for your own safety -if you're not happy, then buy Imperial wheels.  Wink
« Reply #14 on: May 02, 2009, 05:01:28 AM »
So, machine the Reliant hub carrier so that it leaves a slight raised lip in the centre to locate the centre hole in the Nova disc. ,then drill thro the stud holes in the disc to align the new 100mm pcd.I was thinking of doing it that way previously ,but wasnt sure how close the stud holes  were to the edge (corners) of the Reliant hub.
