October 16, 2025, 01:03:43 AM
Bike Tech
stiff clutch on gpz 900r
Topic: stiff clutch on gpz 900r (Read 2610 times)
tony b
April 03, 2009, 03:40:18 PM »
my clutch on the gpz 900r is hydrolic but is very hard to pull back,is this normal/what could be the problem.
Re: stiff clutch on gpz 900r
April 03, 2009, 05:21:50 PM »
I'd be interested in this too! My GPZ750's clutch is stiff to pull too, and even 'notchy' when you do! Not sure if it's hydraulic though!?!
April 03, 2009, 06:14:53 PM »
Cant really help Tony on this but if yours is cabled Clive, then i`d replace the cable. I had the same thing on my KZ and the only thing that helped was an O.E new cable.
gsxrsam
May 17, 2009, 09:54:26 AM »
couple of things..
1 take off slave cyl and check seal/s not full off grease/chain wax/ white powdery cack same as brake calipers...
2 clutch basket can get badly grooved over time causing notchy jerky stiff operation, file down grooves and try that..
