October 16, 2025, 02:07:12 AM *
Pages: 1 [2] 3
Author Topic: MSVA trike lighting positions  (Read 80095 times)
RODeo
« Reply #15 on: July 27, 2011, 05:25:37 PM »
Regarding headlamp type..Im having probs finding 4 1/2" bates lenses that comply.
« Reply #16 on: July 27, 2011, 06:05:09 PM »
Have you tried http://www.jwmotorcycles.com/ and don't forget to tell them your a member on here to get discount.
trikerpete
« Reply #17 on: August 01, 2011, 04:58:16 PM »
Just been reading MSVA trike lighting positions,trikes wider than 1300mm must have lights at least 600mm apart.
Is 1300mm to the out side of the tyres/wheels? if it is then i cant fit my Flapster type lights/indicators cos ive narrowed my axle and do not have the 600mm gap between them!!  Angry
Any thoughts/suggestions?
I think you'll find that 1300 or any other width measurement refers to the widest part of vehicle. Saying that if wing mirrors are widest part, does that count??
steve brock
« Reply #18 on: November 07, 2011, 12:43:21 AM »
Visible hazard warning light does that mean the lights them selves or the switch that operates them?
thebigdogsix
« Reply #19 on: November 07, 2011, 07:48:09 AM »
I think you are referring to the tell tail light. you need one for your indicators and if both of them flash that is ok  Smiley
« Reply #20 on: November 07, 2011, 09:09:51 PM »
I believe if you can see the front indicator lenses from the riding position, you don't need a seperate warning light. I drilled the back of my front indicators & popped in a small amber lens so I could see when they were working.
steven brock
« Reply #21 on: November 22, 2011, 02:48:49 PM »
r reflectors optional?
zakboy
« Reply #22 on: November 22, 2011, 03:34:48 PM »
Non-triangular rear reflector,minimum of 1... if over 1000mm wide 2
« Last Edit: November 22, 2011, 03:36:36 PM by zakboy » Logged
steve brock
« Reply #23 on: November 22, 2011, 09:54:16 PM »
Thanks for the info guys think I have it sort got some front marker lights should add sOme more bling to me thing... Smiley
http://item.mobileweb.ebay.co.uk/viewitem?itemId=140549336359&kw=140549336359
steven brock
« Reply #24 on: August 04, 2012, 11:57:40 PM »
Can a rear reflector be mounted on the side of the mudguard to the rear?
« Reply #25 on: August 05, 2012, 09:57:23 AM »
Can't see why not, as long as it's visible from the rear.
goose
« Reply #26 on: July 29, 2013, 11:56:36 AM »
the gap between front indicators is 24 cm between illuminating surfaces , is that between indicators or indicator and headlight , it doesn't say and I don't want to get it wrong , thanks Huh
« Reply #27 on: July 29, 2013, 12:03:44 PM »
Between the indicators illuminating surfaces. BTW that's minimum, can be more.
goose
« Reply #28 on: July 29, 2013, 12:28:06 PM »
thanks old newbie
andyrennison
« Reply #29 on: July 29, 2013, 03:11:26 PM »
I was thinking of having the indicators on the front, motorbike style, and also on the rear mudguards. Is that allowed ?
Pages: 1 [2] 3
