December 22, 2025, 05:34:04 PM *
Author Topic: PCD INFO  (Read 1816 times)
steve
« on: December 24, 2008, 07:57:07 PM »
Just wanted to know about studs,most wheels i look at say 100mmdia.,reliant axle studs are 4"x4" a differance of 1.6mm,surely this may pose problems? would appreciate some feedback.                Thanks.
« Reply #1 on: December 24, 2008, 09:55:03 PM »
I know nothing but I'm sure there's some info on the main site...........
Ah yes, clicky Here
Hope what you need to know is in there somewhere!
« Reply #2 on: December 25, 2008, 12:28:35 AM »
Hiya Steve,
this has been discussed a couple of times on the forum. Yes, obviously, ideally you should be using Imperial sized wheels with Imperial studs, but as you say, the difference is 1.6mm. Less than 3/4 of a millimetre per stud. A couple of fag papers worth. Bolt the wheels on & take 'em off again a couple of dozen times & the studs & wheel holes will wear more than that. If you're not happy then please don't use them, but all I can say is we've been mixing Metric & Imperial for years with no problems at all.
