April 08, 2026, 08:00:25 PM
Trike Tech
What divvy lights do I need?
Topic: What divvy lights do I need? (Read 2511 times)
Tori
October 10, 2008, 02:46:48 PM »
MOT'ing my trike soon as. The only light on dash I have is indicator warning and hazards. They run off the same red light. Do they need to be seperate, ie, the indicator one being green? Also, do I need a high beam divvy light too? It's not like I can't see it's on! Thanks x
Re: What divvy lights do I need?
October 10, 2008, 04:03:55 PM »
as fa as i now you need 2 indicator flashers,one blue for main beam, ign you already have and hazards i think need to be a separate switch and it must work with the ign off and make yer turn signals flash. im sure some one will tell you different if im wrong
Tori
October 11, 2008, 12:45:14 AM »
serious? ble lihgt for main beam? oh well buggered then. ho hum. ta x
October 11, 2008, 10:14:40 AM »
I agree with VB on the warning lights needed, but only if it was for the MSVA test, I think you`ll be lucky or unlucky depending how you view it, for any MOT inspector to check warning lights ( i`m not even convinced they are covered in an MOT ). As long as they all work how they should, i`d risk it as it is.
Tori
October 11, 2008, 03:21:02 PM »
Ok thanks. Apologies for drivel posted in drunken stupor last night
